I have home assistant running in virtual box on a windows host.
I noticed today that the power draw on that pc is higher than usual, and then I noticed that when looking in task manager, the VM host is consistently using 35-30% CPU but when looking in HA, its showing 2%…
I’m assuming its an addon then ? How might I go about finding out what causing this ?
So it seems that restarting the VM wasn’t enough, even rebooting the host did nothing. This seems to be because the restart or a host reboot saves the current memory state of the VM.
I’ve forced a machine shutdown on the VM and everything is back to normal.
How did you force the shutdown more exactly? I’ve tried everything, even killing it from the task manager, and still have the same problem. The host uses a lot of CPU, while HA is idling.
In my case, I’m running home assistant in VirtualBox on a windows host, soyou have to use the shutdown command from virtualbox menu, that causes the actual HAOS to shutdown rather than just going to sleep.
@szabolcs did you ever figure out what your issue was? I’ve started seeing this problem on my setup since last weekend and havent been eable to figure out what is going on, my VM will eventually take up to 100% cpu on the host and cause windows to freeze until I kill the VM, everything is back to normal then…
