Voice PE - Find your Phone - Modified
This is a modified version of @HowlingCoder’s Voice PE - Find your Phone blueprint. As I noted in that thread, I experienced some issues with the looping aspect of the original.
At this point I’m not sure why some users experience this issue while other users do not, but hopefully this is helpful to someone.
blueprint:
  name: "Voice - Find My Phone - Modified"
  description: Use voice commands to make your phone play TTS repeatedly until dismissed
  author: Didgeridrew
  domain: automation
  input:
    voice_commands:
      description: Command to activate
      default: find my phone
      selector:
        text: {}
    target_device:
      name: Target Phone/Device
      description: Select the phone/ tablet to find
      selector:
        device:
          integration: mobile_app
          multiple: false
    tts_message:
      description: Message to speak repeatedly on the phone
      default: I am here! Your phone is right here!
      selector:
        text: {}
    repeat_interval:
      description: Seconds between TTS repetitions
      default: 2
      selector:
        number:
          min: 2.0
          max: 12.0
          step: 1.0
          mode: slider
    max_duration:
      description: Maximum time to search in minutes (safety timeout)
      default: 5
      selector:
        number:
          min: 1.0
          max: 15.0
          step: 1.0
          mode: slider
trigger_variables:
  device_id: !input target_device
  action_id: DISMISS_PHONE_FINDER_{{device_id}}
  - id: voice
    platform: conversation
    command: !input voice_commands
  - id: found
    event_type: mobile_app_notification_action
    event_data:
      action: "{{action_id}}"
    trigger: event
variables:
  message: !input tts_message
  interval: !input repeat_interval
  max_time: !input max_duration
  notify_service: |
    {{ 'notify.mobile_app_' ~ device_attr(device_id, 'name')|slugify }}
- choose:
    - conditions:
        - condition: trigger
      sequence:
        - action: "{{ notify_service }}"
            message: command_stop_tts
              tag: phone_finder
        - delay:
            milliseconds: 200
            message: clear_notification
              tag: phone_finder
              channel: Phone Finder
        - stop: Phone found
    - conditions:
      sequence:
        - repeat:
            count: "{{ (max_time * 60 / interval) | int(10) }}"
            sequence:
                  title: 📱 Phone Finder
                  message: Finding your phone... Tap to dismiss
                    tag: phone_finder
                    persistent: true
                    importance: max
                    ttl: 0
                    priority: high
                    actions:
                      - action: "{{action_id}}"
                        title: Found It!
              - delay: "{{ 3 if repeat.first else 2 }}"
                  message: TTS
                    ttl: 0
                    priority: high
                    media_stream: alarm_stream
                    tts_text: "{{ message }}"
              - delay: "{{ [interval - 2, 2] | max }}"
              - condition: template
                value_template: "{{ repeat.last }}"
              - data:
                    tag: phone_finder
              - delay:
                  milliseconds: 200
              - data:
                  title: 📱 Phone Finder Timeout
                  message: "Phone finder stopped after {{ max_time }} minutes"
                    tag: phone_timeout
                    timeout: 10
mode: restart
max_exceeded: silent
I made an automation from the blueprint. When I try to prompt my Voice PE, it works great so I am one step closer. I still get the error on my phone saying “failed to notify HA of picked option”
