Voice preview edition esphome update
Hi, I am trying to update home assistant preview edition to ESPHome 2025.12.1 and receive an error.
I have ‘taken control’ of this device because I have added a bme680 sensor to the Gove Port. All was well until ESPHome 2025.12.0.
Can anyone point me in the right direction for a resolution please?
This is the sensor entry:
  - platform: bme680
    i2c_id: grove_i2c
    temperature:
      name: "Bedroom Temperature"
    pressure:
      name: "Bedroom Air Pressure"
    humidity:
      name: "Bedroom Humidity"
    gas_resistance:
      name: "Bedroom Gas Resistance"
    update_interval: 60s
    name: "Bedroom Air Quality"
    icon: "mdi:gauge"
    # calculation: comp_gas = log(R_gas[ohm]) + 0.04 log(Ohm)/%rh * hum[%rh]
    lambda: |-
      return log(id(gas_resistance).state) + 0.04 *  id(humidity).state;
    state_class: "measurement"
and this is the error.
INFO ESPHome 2025.12.1
INFO Reading configuration /config/esphome/home-assistant-voice-bedroom.yaml...
INFO Updating https://github.com/esphome/home-assistant-voice-pe@dev
INFO Updating https://github.com/esphome/esphome@72499eaed2ed54316aca90d368053aa2e1a54f5f
WARNING GPIO46 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq/#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
Failed config
media_source.http_request: [source /data/packages/dc43710d/home-assistant-voice.yaml:1558]
  Component media_source.http_request requires component http_request.
  platform: http_request
  buffer_size: 500000
This has been raised here and on GitHub
25.12.0 errors in ESP Home with "Component media_source.http_request requires component http_request." · Issue #494 · esphome/home-assistant-voice-pe · GitHub which kahrendt closed with the comment:
The http_request component is included in the .factor.yaml file. If you are just using the base yaml file, you’ll have to manually add the http_request component in your adjusted ymal. The new http_request media_source component now requires it.
I’m not even sure what that means. Looks to me (a non-developer) like Voice PE team have added a new feature, sendspin, and hadn’t finished testing before the ESPHome 2025.12.0 release caused a sudden rush of people recompiling the default code from github.
Another issue was raised in github
I checked back, and cannot find any official notification in the ESPHome release notes, or even an announcement in the ESPhome or Voice Assist community forums. :frowning_face:
unrelated to sendspin
looks more like undocumented breaking change; must add http_request:
annoying yes but error message literally says what to do and if you look at the default HAVPE yaml on github it is updated with this change.
just add this to the end of your yaml
http_request:
I had a similar issue when hacking the VPE semdspin yaml.
Thanks, that fixed it. As others pointed out, the solution was actually in the error message. I didn’t make the connection. Thanks for taking the time to respond.
Actually the entire sendspin hasn’t been merged and the entire audio pipeline is a work in progress and subject to change
It works well but it may change
It should be an issue since the many yaml is kept up to date.
