VSCode String does not match the pattern of "DEPRECATED^"
I edit my config files with VSCode on my PC using the Home Assistant Config Helper.
All of a sudden I am now getting the Error reported as “String does not match the pattern of “DEPRECATED^”.” I am not sure why it think there is a problem all of sudden since HA check config doesnt flag it as an issue.
The error is in refrence to - /config just under whitelist .
homeassistant:
  # Name of the location where Home Assistant is running
  latitude: !secret latitude_loc_home
  longitude: !secret longitude_loc_home
  elevation: 475
  unit_system: imperial
  time_zone: America/Los_Angeles
  customize: !include include/customize.yaml
  whitelist_external_dirs:
    - /config
  auth_providers:
Would like to know possible what is causing it or what is deprecated before opening a github issue.
Change
to
allowlist_external_dirs:
Thank you, Guess I missed that breaking change.
I got the same error with quite a few of my scripts. Maybe I missed a breaking change as well?
   - service_template: >
            {%- if is_state('binary_sensor.kookscene', 'off') -%}
              script.cooking_off_donker
            {%- else -%}
              script.cooking_on
            {%- endif %}
Anybody can give me a hint? Thanks!
I see the same warning on (the sensor.garage_rechts_distanz):
  sensors:
    car_presence_right:
      entity_id: sensor.garage_rechts_distanz
      value_template: "{{ states('sensor.garage_rechts_distanz') | float < 1.0 }}"
Anyone an idea, what I am doing wrong?
Remove the entity_id line, you never needed it in the first place in your circumstances.
Okay will try. I thought this tells HA which entity to monitor.
Thanks!
It did IF the template did not have an identifiable entity_id already contained within it, but yours does so the entity_id key was superfluous.
Can you also whisper a solution for my “problem”? The script is still working but it hangs a second or ten on above templating and then continues like it should. Thanks!
Change service_template: to service: :slightly_smiling_face:
Will try that tomorrow! Thanks!
- id: voordeur_notificatie_lang_open
  initial_state: true
  alias: Voordeur te lang open
    platform: state
    entity_id: binary_sensor.voordeur_contact
    to: 'on'
    for:
      minutes: 5
    service_template: notify.telegram #This line gives the error: String does not match the pattern of "DEPRECATED^"
    data_template:
      message: The door is still open!
The notifications still work though. Probably solved it just now by changing service_template: to service: :stuck_out_tongue:
I’m getting this issue in ui-lovelace.yaml now suddenly. I opened the file, added the most recent url entry and now it looks like this:
Thank you so much!
Where do you change this?
