I have a running and working setup of Zwave-JS-UI and HA. Everything is working fine and as expected so far.
The only thing i might be too stupid to get working is using wait_for_trigger in scripts. I have some Fibaro Roller Shutter 2 (FGR222) devices i want to work with in scripts.
So what i am trying to accomplish: Wait for a Cover to change to “closed” and then do some stuff in a script. But the wait_for_trigger always times out. But HA (in developer tools) reports ‘closed’ just as expected.
I’ve never seen this construct before. Most would use the cover.close_cover service call
I would try this. Also the for close may be unnecessary for the script. As it looks like you want it to close within 20 seconds. So having it be closed for 3 seconds, it the same as having a 17 second timeout.
regarding the first thing…yeah this is just what HA does if you pick the device in the UI instead of a service call.
regarding for: …yes, i just want to make sure the state closed is set for 3 sec. the 20 sec timeout is just there because i was unsure what happens if i use no timeout at all…the closed state is reported withing 1-2 sec in my tests according to HA.
The syntax on wait for trigger looks incorrect. Try removing the hyphen on the entitiy id and moving it back up to the prior line like in my example.
Closed could be the wrong state to test for. Take a look in developer tools / states to see what the value is. It may be on or off and the “closed” is the UI translating it based on the device class.
i did! works just fine…returns True/False… all the time. only wait_for_trigger is not working. Maybe i should add that i use wait_for_trigger in a lot of automations with other integrations than zwave. they all work just as documented and expected.
but let me try your approach because i used platform template in wait_for_trigger
First, wait for trigger requires that the trigger happens. So if it is already closed before that the script gets to the trigger it will not trigger. Because zwave service calls do seem to wait for the command to complete in on the zwave network. It would not be surprising for the state to already be updated in HA.
You could test this by adding a call to
- service: system_log.write
level: info
message: "turn_on {{states('cover.my_cover')}} {{now().strftime('%H:%M:%S.%f')[:-3]}}"
logger: service
And see what’s in the log. You may need to make it a warning to show up.
The template, on the other hand, evaluates when it executes, and then will wait if it’s not true for the timeout.
Second, a weird issue with “closed” not be quoted. Likely not the issue though.
The issue is probably that it’s already closed.
I find it really strange but HA needs it to switch to closed while it’s waiting, it can already be closed.
The workaround is to use a if else.
If closed
Do something, preferably a script
else
wait for trigger
end if
this is the correct solution. and it’s not strange. quite explainable.
as @PeteRage said, if the state of the cover is closed already by the time it enters this wait, then the trigger won’t happen in the non-template case because that other method is saying “wait for this change to happen”.
@Hellis81 i would recommend against the “if” check around the wait. this may be mostly hypothetical, but the if check closes the window of vulnerability, but theoretically if the cover achieves close between the if check and the else clause execution (remember there’s no promise that these are atomic) then it can still fail. odds of that happening are very small, but why chance it… negative code beauty points and the template method doesn’t have that vulnerability.
No shit! Aren’t you clever.
Well what if the entity is a device tracker that glitches every now and then and you want to wait for a phone to disconnect from the cars Bluetooth when they are in the home zone.
The device tracker says you are at work even though you are home, the Bluetooth disconnects then the device tracker updates.
Oh? That failed?? Gosh…
In Node red the wait for trigger looks at the current state also which is in my opinion the way it should work.
The wait for trigger in HA makes it complicated for no good reason.
Alright. Thank you so much for your help and the enlightening discussion guys.
It is exactly as @PeteRage pointed out. Right after the service call cover.close_cover the state of the cover changes to closed even though the cover is not really closed yet. If the cover is already very nearly closed before this goes mostly unnoticed. If the cover is mostly open though you can clearly see that right after the service call it changes to closed and just a few seconds later back to open until it is really closed.
I think this is called opportunistic in HA?!
This is the point the for: directive from wait_for_trigger comes in handy. Is there any way to make some sort of for in wait_template/jinja2?
