I received my RPI Zero W which I plan to use as a BLE extender with HA linked to my main instance, hoping it would be a simple endeavor. I did not get the OTG MicroUSB adpapter hoping I wouldn’t need it. I have since ordered one arriving in a few days. Until then… is there an simple fix?!
Wait Until Kernel Time Synchomized [FAILED]
followed by Waiting for the Home Assistant CLI to be ready…
I installed the my-network with my WLAN deets hoping that I would be able to SSH and fix but the device is not joining the WLAN. I have also tried wpa_supplicant and SSH files with no result.
Home Assistant observer
Supervisor:
Disconnected
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[05:08:11] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[05:08:13] INFO: Starting local supervisor watchdog…
21-06-17 05:08:42 INFO (MainThread) [main] Initializing Supervisor setup
21-06-17 05:08:43 INFO (MainThread) [supervisor.docker.network] Can’t find Supervisor network, creating a new network
21-06-17 05:08:45 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-06-17 05:08:45 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi
21-06-17 05:08:46 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armhf-hassio-supervisor with version 2021.05.4
21-06-17 05:08:46 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
21-06-17 05:08:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-06-17 05:08:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-17 05:08:51 INFO (MainThread) [main] Setting up Supervisor
21-06-17 05:08:52 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-06-17 05:08:53 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-06-17 05:08:58 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-17 05:08:59 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-17 05:09:00 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-17 05:09:11 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-17 05:09:11 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-17 05:09:11 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
21-06-17 05:09:11 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-06-17 05:09:12 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/armhf-hassio-dns versions: []
21-06-17 05:09:12 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-dns with version 2021.04.0
21-06-17 05:09:12 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-06-17 05:09:24 INFO (SyncWorker_1) [supervisor.docker.dns] Starting DNS homeassistant/armhf-hassio-dns with version 2021.04.0 - 172.30.32.3
21-06-17 05:09:24 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-06-17 05:09:25 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armhf-hassio-audio versions: []
21-06-17 05:09:25 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-audio with version 2021.04.0
21-06-17 05:09:25 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-06-17 05:09:39 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/armhf-hassio-audio with version 2021.04.0 - 172.30.32.4
21-06-17 05:09:40 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armhf-hassio-cli versions: []
21-06-17 05:09:40 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-cli with version 2021.05.1
21-06-17 05:09:41 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
21-06-17 05:10:03 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/armhf-hassio-cli with version 2021.05.1 - 172.30.32.5
21-06-17 05:10:04 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armhf-hassio-observer versions: []
21-06-17 05:10:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-observer with version 2020.10.1
21-06-17 05:10:05 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
21-06-17 05:10:16 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/armhf-hassio-observer with version 2020.10.1 - 172.30.32.6
21-06-17 05:10:17 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/armhf-hassio-multicast versions: []
21-06-17 05:10:17 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-multicast with version 2021.04.0
21-06-17 05:10:17 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-06-17 05:10:25 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/armhf-hassio-multicast with version 2021.04.0 - Host
21-06-17 05:10:25 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-17 05:10:35 INFO (MainThread) [supervisor.plugins] dns does not have the latest version 2021.06.0, updating
21-06-17 05:10:35 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/armhf-hassio-dns:2021.04.0 to ghcr.io/home-assistant/armhf-hassio-dns:2021.06.0
21-06-17 05:10:35 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/armhf-hassio-dns with tag 2021.06.0.
21-06-17 05:12:33 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping hassio_dns application
21-06-17 05:12:40 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
21-06-17 05:12:41 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: [‘homeassistant/armhf-hassio-dns:2021.04.0’]
21-06-17 05:12:45 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-06-17 05:12:54 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/armhf-hassio-dns with version 2021.06.0 - 172.30.32.3
21-06-17 05:12:55 INFO (MainThread) [supervisor.plugins] observer does not have the latest version 2021.06.0, updating
21-06-17 05:12:55 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/armhf-hassio-observer:2020.10.1 to ghcr.io/home-assistant/armhf-hassio-observer:2021.06.0
21-06-17 05:12:55 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/armhf-hassio-observer with tag 2021.06.0.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[05:15:57] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[05:15:59] INFO: Starting local supervisor watchdog…
21-06-17 05:16:27 INFO (MainThread) [main] Initializing Supervisor setup
21-06-17 05:16:28 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-06-17 05:16:28 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi
21-06-17 05:16:28 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armhf-hassio-supervisor with version 2021.05.4
21-06-17 05:16:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-06-17 05:16:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-17 05:16:30 INFO (MainThread) [main] Setting up Supervisor
21-06-17 05:16:31 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-06-17 05:16:33 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-06-17 05:16:38 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-17 05:16:38 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-17 05:16:40 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-17 05:16:51 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-17 05:16:51 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-17 05:16:51 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
21-06-17 05:16:51 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-06-17 05:16:52 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-dns with version 2021.06.0
21-06-17 05:16:52 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
21-06-17 05:16:52 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
21-06-17 05:17:04 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/armhf-hassio-dns with version 2021.06.0 - 172.30.32.3
21-06-17 05:17:04 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
21-06-17 05:17:04 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-audio with version 2021.04.0
21-06-17 05:17:05 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
21-06-17 05:17:05 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
21-06-17 05:17:30 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/armhf-hassio-audio with version 2021.04.0 - 172.30.32.4
21-06-17 05:17:30 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-cli with version 2021.05.1
21-06-17 05:17:31 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
21-06-17 05:17:31 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_cli application
21-06-17 05:17:56 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI homeassistant/armhf-hassio-cli with version 2021.05.1 - 172.30.32.5
21-06-17 05:17:56 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-observer with version 2020.10.1
21-06-17 05:17:57 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/armhf-hassio-multicast with version 2021.04.0
21-06-17 05:17:57 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-06-17 05:17:57 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
21-06-17 05:18:14 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/armhf-hassio-multicast with version 2021.04.0 - Host
21-06-17 05:18:14 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-17 05:18:25 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-17 05:18:26 INFO (MainThread) [supervisor.plugins] observer does not have the latest version 2021.06.0, updating
21-06-17 05:18:26 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/armhf-hassio-observer:2020.10.1 to ghcr.io/home-assistant/armhf-hassio-observer:2021.06.0
21-06-17 05:18:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/armhf-hassio-observer with tag 2021.06.0.
21-06-17 05:19:09 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-17 05:19:09 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping hassio_observer application
21-06-17 05:19:17 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_observer application
21-06-17 05:19:20 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: [‘homeassistant/armhf-hassio-observer:2020.10.1’]
21-06-17 05:19:30 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
21-06-17 05:19:47 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/armhf-hassio-observer with version 2021.06.0 - 172.30.32.6
21-06-17 05:19:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-17 05:19:58 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-17 05:19:58 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-06-17 05:19:59 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for homeassistant/raspberrypi-homeassistant
21-06-17 05:19:59 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image homeassistant/raspberrypi-homeassistant found.
21-06-17 05:20:00 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi-homeassistant with version landingpage
21-06-17 05:20:00 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
21-06-17 05:20:00 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-06-17 05:20:00 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
21-06-17 05:20:09 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/raspberrypi-homeassistant with version landingpage
21-06-17 05:20:10 INFO (MainThread) [supervisor.hassos] Detect Home Assistant Operating System 6.0 / BootSlot A
21-06-17 05:20:10 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
21-06-17 05:20:10 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - home-assistant/addons: Docker add-ons for Home Assistant repository
21-06-17 05:20:55 INFO (MainThread) [supervisor.store] Loading add-ons from store: 63 all - 63 new - 0 remove
21-06-17 05:20:55 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-06-17 05:20:55 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-06-17 05:20:55 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-06-17 05:20:55 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-06-17 05:20:55 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-06-17 05:20:55 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-17 05:20:55 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-06-17 05:20:57 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-17 05:20:57 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - CoreState.SETUP
21-06-17 05:20:57 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-06-17 05:20:58 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-17 05:20:58 INFO (MainThread) [main] Running Supervisor
21-06-17 05:20:59 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-06-17 05:20:59 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
21-06-17 05:21:10 ERROR (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
21-06-17 05:21:10 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
21-06-17 05:21:10 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-06-17 05:21:11 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2021.06.3
21-06-17 05:21:11 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/armhf-hassio-supervisor with tag 2021.06.3.
21-06-17 05:24:42 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
21-06-17 05:24:42 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
21-06-17 05:24:42 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
21-06-17 05:24:42 INFO (MainThread) [supervisor.core] Supervisor is down - 0
21-06-17 05:24:43 INFO (MainThread) [main] Closing Supervisor
s6-svwait: fatal: timed out
[fix-attrs.d] done.
[05:27:21] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[05:27:23] INFO: Starting local supervisor watchdog…
21-06-17 05:27:50 INFO (MainThread) [main] Initializing Supervisor setup
21-06-17 05:27:51 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
21-06-17 05:27:52 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi
21-06-17 05:27:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armhf-hassio-supervisor with version 2021.05.4
21-06-17 05:27:52 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
21-06-17 05:27:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-17 05:27:54 INFO (MainThread) [main] Setting up Supervisor
21-06-17 05:27:55 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
21-06-17 05:27:56 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
21-06-17 05:28:02 INFO (MainThread) [supervisor.host.info] Updating local host information
21-06-17 05:28:02 INFO (MainThread) [supervisor.host.services] Updating service information
21-06-17 05:28:04 INFO (MainThread) [supervisor.host.network] Updating local network information
21-06-17 05:28:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-06-17 05:28:15 INFO (MainThread) [supervisor.host] Host information reload completed
21-06-17 05:28:15 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
21-06-17 05:28:15 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
21-06-17 05:28:16 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-a
