This is what I was seeing in logs once enabling debugging mode (see here for details https://developers.home-assistant.io/docs/operating-system/debugging/), you need debug mode in order to be able to SSH to the HA server:
# systemctl status systemd-timesyncd.service
Warning: The unit file, source configuration file or drop-ins of systemd-timesyncd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/systemd-timesyncd.service.d
└─hassos.conf, ro.conf
Active: active (running) since Fri 2020-02-07 15:50:57 UTC; 2h 45min ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 285 (systemd-timesyn)
Status: "Idle."
Tasks: 2 (limit: 4915)
Memory: 1020.0K
CGroup: /system.slice/systemd-timesyncd.service
└─285 /usr/lib/systemd/systemd-timesyncd
Feb 07 16:09:53 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.123:123 (time.cloudflare.com).
Feb 07 16:10:03 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.1:123 (time.cloudflare.com).
Feb 07 16:27:18 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.1:123 (time.cloudflare.com).
Feb 07 16:27:28 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.123:123 (time.cloudflare.com).
Feb 07 17:01:47 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.1:123 (time.cloudflare.com).
Feb 07 17:01:57 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.123:123 (time.cloudflare.com).
Feb 07 17:36:15 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.1:123 (time.cloudflare.com).
Feb 07 17:36:26 homeassistant systemd-timesyncd[285]: Timed out waiting for reply from 162.159.200.123:123 (time.cloudflare.com).
Feb 07 18:06:54 homeassistant systemd-timesyncd[285]: Network configuration changed, trying to establish connection.
Time sync is not working with time.cloudflare.com hosts.
After debug access is set up you can SSH to the HA server where you will be presented with the hypervisor prompt, type login to get to a shell prompt:
❯ ssh [email protected] -p 22222
Warning: Permanently added '[192.168.10.17]:22222' (ECDSA) to the list of known hosts.
_ _ _ _ _
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ ` _ \ / _ \ / /\ \ / __/ __| / __| __/ _` | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome on Home Assistant command line.
For more details use 'help' and 'exit' to close.
If you need access to host system use 'login'.
ha > login
I modified the NTP server entry: vi /etc/systemd/timesyncd.conf
Reloaded systemd config: systemctl daemon-reload
Restarted timesyncd service: systemctl restart systemd-timesyncd.service
Confirmed time was now syncing: systemctl status systemd-timesyncd.service
Active: active (running) since Sat 2020-09-19 15:09:05 UTC; 2s ago
Main PID: 4587 (systemd-timesyn)
Status: "Initial synchronization to time server 192.168.10.1:123 (192.168.10.1)."
Memory: 552.0K
└─4587 /usr/lib/systemd/systemd-timesyncd
Sep 19 15:09:05 homeassistant systemd[1]: Starting Network Time Synchronization...
Sep 19 15:09:05 homeassistant systemd[1]: Started Network Time Synchronization.
Sep 19 15:09:05 homeassistant systemd-timesyncd[4587]: Initial synchronization to time server 192.168.10.1:123 (192.168.10.1).
Once this was done I restarted the HA supervisor service: systemctl restart hassos-supervisor.service
