Interesting use case. If you’re able to use Bluetooth I can add OCPP settings as a home assistant service in my integration?
I’ve documented almost the entire protocol; wifi settings, schedules, software updates, restore, front LED setting (did you know you can dim the leds?). Let me know if there’s some specific needs.
You can control the LEDs?!?!? Friend, you’re in for a statue hahaha!
Joking, we knew they could control all this but for some reason they keep avoiding providing control via the API.
My only fear is that they’ll stop this by implementing some extra encryption on the bluetooth interface…
Thanks. I will take a look as some point.
My first issue is the distance between HA and Wallbox is too far for Bluetooth, so will need to look at proxy options.
I tried the proxy using an esp32 - whilst it automatically picked up my switch bot [pleasant surprise, forgot I had one!] it could not find the wallbox unfortunately.
Keen to hear if others are more successful and/or if you’ve taken additional steps to put the wallbox in pairing mode.
Range is not an issue here as the proxy was within one meter of the wallbox.
So, I just installed an ESP32 bluetooth proxy and indeed it picked up the Wallbox immediately.
I don’t have any entity available (but they’re there!) because the car is not connected. @RT1080 I don’t know why yours is not picking up - maybe play around with the ble proxy parameters… also, I believe it can only pick up 3 ble items at once, so it could also be that it’s overwhelmed ?
It’s Locked/Unlocked - you can test it in developer settings by checking the state.
What are you trying to achieve though? Mine is locked when charging and locked when not charging - would it not be easier to assess the status description sensor? This also shows “charging”, “waiting for car demand”, “locked, plugged in” etc.
I changed the esp32 settings in line with your code - now it works. But same as you all entities are unavailable. My car is connected, charged to the max so perhaps it’s that - otherwise the bluetooth proxy element may be the cause?
Is it as intended that the bluetooth connection is fully unprotected? Eg. when my new bt proxy was onboarded the Wallbox BLE showed up as new device and was added without any input requirements - I recall when I connected the first time by phone I was prompted to provide a serial number of some sorts?
You’re right… didn’t think of that! So the whole security concept relies on their app not letting you connect to a foreign Wallbox?!?
Then all the user, password etc… on the website is just facade. If you’re in BT range you can unlock any Wallbox.
Should we notify our contact @ Wallbox about this?
That’s from AGES ago!
It’s not the same vulnerability, it merely points out that by using a CM4 your wallbox is exposed to anyone who would break in and open it up.
This is a whole new level.
