Dakhaas
February 10, 2022, 7:15pm
1
I get a lot of warnings:
Logger: homeassistant.components.sensor
Source: /usr/local/lib/python3.9/asyncio/events.py:80
Integration: Sensor (documentation, issues)
First occurred: 19:30:11 (1 occurrences)
Last logged: 19:30:11
Setup of sensor platform mqtt is taking over 10 seconds.
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:568
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 19:34:41 (1 occurrences)
Last logged: 19:34:41
Can't read Supervisor data:
Logger: homeassistant.components.zha.core.channels.base
Source: components/zha/core/channels/base.py:428
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 19:31:26 (3 occurrences)
Last logged: 19:31:26
[0x17C6:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('[0x17c6:1:0x0008]: Message send failure'), DeliveryError('[0x17c6:1:0x0008]: Message send failure'), DeliveryError('[0x17c6:1:0x0008]: Message send failure'), DeliveryError('[0x17c6:1:0x0008]: Message send failure')]
[0x17C6:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('[0x17c6:1:0x0300]: Message send failure'), DeliveryError('[0x17c6:1:0x0300]: Message send failure'), DeliveryError('[0x17c6:1:0x0300]: Message send failure'), DeliveryError('[0x17c6:1:0x0300]: Message send failure')]
[0x17C6:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('[0x17c6:1:0x0006]: Message send failure'), DeliveryError('[0x17c6:1:0x0006]: Message send failure'), DeliveryError('[0x17c6:1:0x0006]: Message send failure'), DeliveryError('[0x17c6:1:0x0006]: Message send failure')]
Logger: homeassistant.setup
First occurred: 19:29:45 (3 occurrences)
Last logged: 19:30:01
Setup of input_boolean is taking over 10 seconds.
Setup of script is taking over 10 seconds.
Setup of automation is taking over 10 seconds.
and one error:
Logger: homeassistant.config
Source: config.py:454
First occurred: 19:29:35 (1 occurrences)
Last logged: 19:29:35
Invalid config for [automation]: required key not provided @ data['action']. Got None required key not provided @ data['trigger'][1]['platform']. Got None. (See /config/configuration.yaml, line 10).
tmjpugh
(Tmjpugh)
February 10, 2022, 7:47pm
2
The automation is missing info
Key = the defined data
So it has no data for action and trigger
It say to check line 10 of config file but likely this wrong.
Dakhaas
February 10, 2022, 8:34pm
3
line 10 actually is commented, line 11 refers to automations file
- id: '1639339730308'
alias: poco batt boven 90%
description: ''
- platform: state
entity_id: binary_sensor.m2007j20cg_is_charging
condition:
- type: is_battery_level
condition: device
device_id: eefdf074e09c6a279ec849e73468f4cb
entity_id: sensor.m2007j20cg_battery_level
domain: sensor
above: 90
below: 89
- type: turn_off
device_id: b1af88310cf780276e2ef3b8ddfff2cf
entity_id: switch.s26_5
domain: switch
mode: single
- id: '1640110380047'
alias: PCslk-powerup
description: dan s263 en s266 ook aan
- platform: numeric_state
entity_id: sensor.pow3_energy_power
is the beginning of the automations file. Where to look for missing stuff??
tmjpugh
(Tmjpugh)
February 10, 2022, 9:01pm
4
NO. it want you to look at config so start there.
many times the cause of these are missing quote mark or some other typo before line indicated.
In any case its is causing and error in your automation.
finity
February 10, 2022, 11:56pm
5
If that is your complete automations file then the second automation there is missing the action section.
Dakhaas
February 11, 2022, 1:05am
6
the line below the automations part describes which part it is. the actual automations text is much much longer …410 lines
Dakhaas
February 11, 2022, 1:10am
7
all of config.yaml:
I noticed the spaces before plarform of tts… could that be??
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
# group: !include groups.yaml <<---- LINE 10
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
switch: !include switches.yaml
# Example configuration.yaml entry
logger:
default: info
google_assistant:
project_id: hassnnnnnnxxxxxxxx.json
report_state: true
exposed_domains:
- switch
- light
entity_config:
switch.RGB:
aliases:
- BRIGHT_LIGHTS
- ENTRY_LIGHTS
light.living_room:
expose: false
room: woonkamer
python_script:
# publish mqtt feed of ilumination sensor
mqtt_statestream:
base_topic: home
publish_attributes: true
publish_timestamps: true
# Example filter to include specified domains and exclude specified entities
include:
# domains:
# - serre
# entity_globs:
entities:
- sensor.lumi_lumi_sen_ill_mgl01_illuminance
# exclude:
# entities:
# - light.kitchen_light
Dakhaas
February 11, 2022, 1:30am
8
removed 1 space before tts platform line.
now errors:
02:23:25 – (FOUT) config.py - bericht kwam voor het eerst om 02:23:15 en verschijnt 2 keer
:0:0 ResizeObserver loop completed with undelivered notifications.
02:19:53 – (FOUT) components/system_log/__init__.py
Dakhaas
February 11, 2022, 1:39am
10
Where has Wordperfect 5.0 gone? Where even Hard-returns were visible.
I see this ‘spaces matter’ and line counting errors as Serious Design Flaws.
Script.yaml:
script_publish_mqtt_lumi:
alias: script-publish-mqtt lumi
sequence:
- service: mqtt.publish
topic: home/lumi
payload_template: '{{ states(''sensor.lumi_lumi_sen_ill_mgl01_illuminance'')
mode: restart
icon: mdi:alarm-light
pwr_kk_serre_max:
alias: pwr kk serre max
sequence:
- condition: state
entity_id: sensor.shp24_energy_today
attribute: unit_of_measurement
state: '>0.150'
for:
hours: 0
minutes: 0
seconds: 2
- type: turn_off
device_id: 48bfc30edab99c4d2bd32a9736ebbec7
entity_id: switch.shp24_koelkast_serre
domain: switch
mode: single
icon: mdi:fridge
automations complete:
description: ''
- platform: state
condition:
condition: device
device_id: eefdf074ec849e73468f4cb
domain: sensor
above: 90
below: 89
- type: turn_off
device_id: b1af88310c8ddfff2cf
domain: switch
mode: single
below: '16'
condition: []
- type: turn_on
device_id: 8add2c89c1722b
entity_id: switch.s263_slk_logitech
domain: switch
- type: turn_on
device_id: 6cb4111681dc1c1b05
entity_id: switch.s266
domain: switch
mode: single
- id: '1640110568580'
alias: Pow3SlkPowerDown
description: dan spk en moni ook down
- platform: state
to: '17'
condition: []
- type: turn_off
device_id: 8add253d1722b
domain: switch
- type: turn_off52ee156c6563d111681dc1c1b05
domain: switch
mode: single
- id: '1643305203364'
alias: 6349 pir auto
description: ''
use_blueprint:
path: homeassistant/motion_light.yaml
input:
motion_entity: binary_sensor.pir6349_ias_zone
light_target:
device_id: de303909b12ce1067454b92bdfc09898
- id: '1643330695215'
alias: ZHA - Aqara Opple - Wireless Scene Switch 6 Button
description: ''
use_blueprint:
path: Jarne_Roussard/aqara-opple-6-buttons-for-zha.yaml
input:
remote: aaad479a8daa866ba6682d6ea2206de7
button_top_left_single_press:
- type: turn_off
device_id: 26debc57a396b07227e8654fdce970ff
entity_id: switch.power1
domain: switch
button_top_right_single_press:
- type: turn_on
domain: switch
button_middle_left_single_press:
- type: turn_off
entity_id: switch.power2
domain: switch
button_middle_right_single_press:
- type: turn_on
domain: switch
button_bottom_left_single_press:
- type: turn_off
device_id: 31e0e0e87e7c577abe15de09ef404038
entity_id: switch.touch
domain: switch
button_bottom_right_single_press:
- type: turn_on
domain: switch
button_bottom_right_hold_in: []
button_bottom_left_hold_in: []
button_middle_left_double_press:
- type: turn_off
domain: switch
- type: turn_off
domain: switch
- type: turn_off
domain: switch
button_bottom_left_hold_release:
- type: turn_off
device_id: 408eb9504af37302eafe2eb202956c20
entity_id: switch.t2_badkamer
domain: switch
- type: turn_off
entity_id: switch.t2_douche
domain: switch
- type: turn_off
device_id: 69af15f75a479c8bbf9b061528c3c740
entity_id: switch.th5_slkkast
domain: switch
- type: turn_off
domain: switch
- type: turn_off
domain: switch
- type: turn_off
domain: switch
- type: turn_off
device_id: da8d8838ebc9d98dc4d8990f7b173d9f
entity_id: switch.s260
domain: switch
- type: toggle
device_id: 4780ec46a619b414612c32e619e04b20
entity_id: light.bw_lt21_2
domain: light
button_bottom_right_hold_release:
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: toggle
domain: light
- type: toggle
domain: switch
button_middle_right_hold_in:
- type: turn_on
device_id: da371e6113c3e3800f91d4003669c2fd
entity_id: light.cl01_6245a523_level_light_color_on_off
domain: light
brightness_pct: 80
- type: turn_on
entity_id: light.cl02_level_light_color_on_off
domain: light
brightness_pct: 80
- type: turn_on
domain: light
brightness_pct: 80
button_middle_left_hold_in:
- type: turn_off
domain: light
- type: turn_off
domain: light
- type: turn_off
domain: light
button_top_left_double_press:
- type: turn_off
device_id: f329d23c8c3cca11015eff160a55cb53
entity_id: switch.th2_buitenverlichting_2
domain: switch
button_top_right_double_press:
- type: turn_on
domain: switch
button_middle_right_double_press:
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: turn_on
domain: switch
- type: toggle
domain: switch
button_bottom_left_double_press:
- type: turn_off
domain: switch
button_bottom_left_triple_press:
- type: turn_off
device_id: 31e0e0ee09ef404038
domain: switch
button_bottom_right_double_press:
- type: turn_on
domain: switch
- alias: rfbridge_demultiplexer
- platform: mqtt
topic: tele/RFA/RESULT
- service: python_script.rfbridge_demux
data_template:
payload: '{{trigger.payload_json.RfReceived.Data}}'
- id: '1643719902152'
alias: post lumi 5min
description: ''
- platform: time_pattern
minutes: '5'
condition: []
topic: lumi
payload_template:
mode: single
- id: '1643800522764'
alias: pir8-lamp cl1
description: ''
use_blueprint:
path: freakshock88/motion_illuminance_activated_entity.yaml
input:
motion_sensor: sensor.pir8
target_entity: light.cl01_6245a523_level_light_color_on_off
illuminance_sensor: sensor.lumi_lumi_sen_ill_mgl01_illuminance
no_motion_wait: '2'
- id: '1643800753626'
alias: zb pir slk-slkkast
description: ''
use_blueprint:
input:
motion_sensor: binary_sensor.pir6349_on_off
target_entity: switch.th5_slkkast
no_motion_wait: '5'
- id: '1643823829103'
alias: automation--run-script-mqtt-on-pir6
description: ''
use_blueprint:
input:
motion_sensor: sensor.pir6
target_entity: script.script_publish_mqtt_lumi
- id: '1643898227338'
alias: serre shp24 getimed script kk verbruik
description: ''
hours: '2'
condition: []
- service: script.pwr_kk_serre_max
data: {}
mode: single
- id: '1644312641529'
alias: rfknop3-switch slk moni
description: ''
- platform: state
entity_id: sensor.rfsonoff3
condition: []
- type: toggle
device_id: 6cb4a52ee156c6563d111681dc1c1b05
entity_id: switch.s266_slk_monitor
domain: switch
mode: single
- id: '1644312779283'
alias: rfknop4 -switch-slk-logitech s263
description: ''
- platform: state
entity_id: sensor.rfsonoff4
condition: []
- type: toggle
device_id: 8add253de16dbebba53d7bbc89c1722b
domain: switch
mode: single
- id: '1644312934854'
alias: rfsonof1-slkast1
description: ''
- platform: state
entity_id: sensor.rfsonoff1
condition: []
- type: turn_on
domain: switch
mode: single
- id: '1644313008623'
alias: rfsonof2-slkast uit
description: ''
- platform: state
entity_id: sensor.rfsonoff2
condition: []
- type: turn_off
domain: switch
mode: single
- id: '1644313184806'
alias: rfsonof5-toggle-douche
description: ''
- platform: state
entity_id: sensor.rfsonoff5
condition: []
- type: toggle
domain: switch
mode: single
- id: '1644313187716'
description: ''
- platform: state
condition: []
- type: toggle
domain: switch
mode: single
- id: '1644313254415'
alias: rfsonof6-toggle-wastafel
description: ''
- platform: state
entity_id: sensor.rfsonoff6
condition: []
- type: toggle
domain: switch
mode: single
Dakhaas
February 11, 2022, 1:58am
11
log of errors after a reboot/update
Error doing job: Task exception was never retrieved
02:55:07 – (FOUT) util/dt.py
Error during xml -> python translation
02:55:07 – (FOUT) /usr/local/lib/python3.9/site-packages/zeep/xsd/types/simple.py
Unable to parse event from E0:62:90:C7:B4:09: { 'SubscriptionReference': None, 'Topic': { '_value_1': 'tns1:RuleEngine/CellMotionDetector/Motion', 'Dialect': 'http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet', '_attr_1': { } }, 'ProducerReference': None, 'Message': None }
02:55:02 – (WAARSCHUWING) ONVIF - bericht kwam voor het eerst om 02:54:39 en verschijnt 5 keer
02:55:02 – (FOUT) /usr/local/lib/python3.9/site-packages/zeep/xsd/types/simple.py - bericht kwam voor het eerst om 02:53:46 en verschijnt 12 keer
02:54:53 – (FOUT) components/dhcp/__init__.py
02:54:43 – (WAARSCHUWING) Zigbee Home Automation - bericht kwam voor het eerst om 02:54:42 en verschijnt 3 keer
Received message for unregistered webhook db07d21eda1981534806d5aac04 from 192.168.10.211
02:54:35 – (WAARSCHUWING) Webhook - bericht kwam voor het eerst om 02:54:35 en verschijnt 2 keer
Invalid discovery topic tasmota/discovery/HomeAssistant:
02:53:52 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/hatasmota/discovery.py
02:53:37 – (WAARSCHUWING) Sensor
Setup of input_button is taking over 10 seconds.
02:53:37 – (WAARSCHUWING) /usr/local/lib/python3.9/asyncio/events.py - bericht kwam voor het eerst om 02:53:07 en verschijnt 8 keer
Unknown cluster 57346
02:53:32 – (WAARSCHUWING) /usr/local/lib/python3.9/site-packages/zigpy/zcl/__init__.py - bericht kwam voor het eerst om 02:53:32 en verschijnt 2 keer
Platform mqtt does not generate unique IDs. ID 2cb868 already exists - ignoring sensor.blauwd
02:53:27 – (FOUT) Sensor
Config entry 'P1 meter (3c39e727d56e)' for homewizard integration not ready yet: Error connecting to the Energy device at 192.168.10.108; Retrying in background
02:53:25 – (WAARSCHUWING) config_entries.py
Setup of weather platform buienradar is taking over 10 seconds.
02:53:17 – (WAARSCHUWING) Weather
02:53:03 – (FOUT) config.py
Can't read Supervisor data: Container addon_a0d7b954_ssh is not running
02:52:52 – (WAARSCHUWING) Home Assistant Supervisor
tom_l
February 11, 2022, 2:04am
12
Nope. It’s how yaml, python and text editors work. You need to learn it.
Here’s the first issue I found. This:
- platform: mqtt
data_template:
Should be:
- platform: mqtt
data_template:
was indented too far. it should be at the same level as trigger:
Dakhaas
February 11, 2022, 2:08am
13
tom_l:
still no argument that it is not a design flaw.
Dakhaas
February 11, 2022, 2:12am
14
Wow, you’re good. That was like line 261, or 260
tom_l
February 11, 2022, 2:21am
15
Spaces matter because that is how YAML works.
This:
key_1: value
key_a: value
key_b: value
is very different to this:
key_1: value
key_a: value
key_b: value
They define different data structures. Spacing is important in YAML, it’s how it works. You can read more here: http://thomasloven.com/blog/2018/08/YAML-For-Nonprogrammers/
As to why Python starts counting at 0 but most text editors start counting lines at 1, it’s just the way it is.
123
(Taras)
February 11, 2022, 4:50am
16
Speaking of design flaws, your design of this statement is flawed:
state: '>0.150'
You appear to be trying to perform a numeric comparison within a State Condition . However, if you review its documentation, you’ll see that’s not the correct type of condition to use for numeric tests. In addition, you made the State Condition monitor the entity’s unit_of_measurement
attribute. That’s incorrect because that attribute doesn’t contain a numeric value.
In addition to learning about YAML, I suggest you review the documentation describing the many different types of conditions. I believe the Numeric State Condition may be what you want.
Dakhaas
February 11, 2022, 9:09am
17
pwr_kk_serre_max:
sequence:
- condition: numeric_state
above: 0.150
# for:
# hours: 0
# minutes: 0
# seconds: 2
- type: turn_off
domain: switch
mode: single
icon: mdi:fridge
better? we’ll see if it works now
The notifications malfunction… there are none. Maybe it needs a reboot.
tom_l
February 11, 2022, 9:17am
18
Dakhaas:
better?
Nope.
You are monitoring the attribute unit_of_measurement
. Which is the string kWh (or Wh), this does not change. You want to monitor the state. So remove attribute: unit_of_measurement
from the condition.
Dakhaas
February 11, 2022, 2:28pm
19
pwr_kk_serre_max:
sequence:
# attribute: unit_of_measurement
above: 0.030
# for:
# hours: 0
# minutes: 0
# seconds: 2
- type: turn_off
domain: switch
mode: single
icon: mdi:fridge
It seems it still does not work
tom_l
February 11, 2022, 2:59pm
20
That’s appears to be a script, not an automation. How are you calling the script?
It won’t do anything automatically. For that you need an automation.
