Water flow sensor with zigbee
I want to send the water flow details to hassio. I saw that we can put this on the pipe: https://www.aliexpress.com/item/32810569662.html?spm=a2g0o.detail.1000023.1.6130440eVmDOnE
but which module do I have to build to connect this walve? Is not possible to conect directly to Rasberry. So I have to send thorough zigbee the data.
Find a way to connect that to a Zigbee solution will be much harder than connecting that sensor to a Raspberry or an ESP.
Take a look at this discussion: Using ESPhome to build a water flow rate meter - #25 by saboaua
And this (in spanish, but with subtitles)
Also se related discussion here:
Did you manage to find a solution that worked over the zigbee network?
