I’m trying to integrate my home water and gas usage into HA. I bought a cheap water flow meter with built in hall sensor from ali, but it wasn’t accurate at low flow rates. The home’s water utility meter is very accurate. For $10 an easp32 and a QMC5883L Magnetometer can sufficiently read magnetic changes inside the meters!
I’m just struggling to convert the sine wave reported over i2c into pulse count data. I have tried using lambda as a trigger when sensor value reaches a high point in the curve, but i’m lost in then feeding that to a pulse counter.
I thought about trying to output the signal, using a GPIO to another pin on the board setup as a pulse counter, but it seems like there must be an easier way i’m missing.
I wouldn’t think you would be able to feed into a pulse counter from a sensor, the pulse counters are hardware in the chip that count pulses at the pin.
I would think you would need to use a custom sensor that would count the pulse internally.
I’m looking to do the same thing, but had hoped that someone has already done the work.
I havn’t spent much time on it. I did find a solution by using mysensors that I’ll probably use eventually. I’m sure ESPhome can provide the same functionality, but I lack the understanding to make it work right now.
Every time your binary sensor turns on, turn on a GPIO output (using on_press and on_release). Short this to another GPIO input that you can feed to your pulse counter.
I will try this out this week. My current current setup does measure the field strength peaks accurately. I just need this counter solution to make is useable. Thanks Tom.
So I have something that is mostly working and if your cycles are as long as they look it may work for you. It’s not for me because the qmc5883l is only sampling once a second and my meter spins faster than that.
Thanks for this. I am able to monitor my water at my water softener turbine sensor using your code with some modifications. The turbine can spin about 30rps so setting the interval to 5ms works perfectly.
