I’m looking for a water leak detector that I could stick to the side of my sump pump bucket. All the ones I have seen show them sitting on the floor but I want to trigger before the water gets to the floor. Right now my main integrations are Insteon and Wi-Fi devices but open to other options. Any suggestions would be appreciated. Thanks
If you get the Aqara leak sensor it has 2 removeable leads on the bottom. You can attach a couple wires to those leads and place those wires at the level you want in the bucket. Just keep the bare wire ends about a 1/4 inch apart. Once water gets to those wires it will trigger the sensor.
Based on experience, I’d forego a water level sensor for a float switch. I tried the sensor route and found moisture accumulated on the sensor probe during heavy drainage (rainy) periods. The accumulated water would triggered false alarms. Moving to a float, instead of a sensor, solved the problem.
Thanks. I’ll take a look
Thanks for the suggestion. May I ask what switch you used?
I purchased it on Amazon. Here’s a link to the Float Switch I used
awesome. Thanks. What water sensor did you end up using?
I’m not sure I understand this question. I used an ESP8266 with the float switch purchased from Amazon. Here’s the code for the ESP8266;
# Establish Substitutions
substitutions:
esphome_name: sump-water-level-monitor
esphome_platform: ESP8266
esphome_board: d1_mini
esphome_comment: Sump Well High Water Level Monitor
esphome_project_name: "Robert.Sump Well High Water Level Warning"
esphome_project_version: "sump-well-water-level-monitor__2023_02_01_06"
devicename: sump_water_level_monitor
upper_devicename: Sump Water Level Monitor
#Define Project Deatils and ESP Board Type
esphome:
platform: $esphome_platform
board: $esphome_board
comment: $esphome_comment
project:
version: $esphome_project_version
# WiFi connection, replace these with values for your WiFi.
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption
# Enable over-the-air updates.
ota:
password: !secret ota_password
# Enable Web server.
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: $devicename ESPHome Version
# Expose WiFi information as sensor.
- platform: wifi_info
ip_address:
ssid:
bssid:
mac_address:
# Button to restart the sump-water-level-monitor.
button:
- platform: restart
# Enable On-Board Status LED.
status_led:
pin:
# Pin D4
number: GPIO2
inverted: true
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: $devicename WiFi Signal
update_interval: 60s
# Define output for "Sump High Level Alert"
output:
- platform: esp8266_pwm
pin:
# Pin D2
number: GPIO4
# Define Water Level Sensor Input
binary_sensor:
- platform: gpio
pin:
# Pin D3
inverted: true
number: GPIO0
mode:
input: true
pullup: true
name: "Sump Water Level Monitor"
device_class: moisture
on_state:
- while:
condition:
binary_sensor.is_on: sump_sensor
then:
- script.execute: flash_led
- delay: 500ms
# Flash High Water Level Alert LED
script:
- id: flash_led
mode: single
then:
- output.turn_on: alarm_led
- delay: 250ms
- output.turn_off: alarm_led
Based on your comment, I actually called a manufacturer and asked if the sensor could be used in a sump pump pit. The guy was very nice and initially said it would work. But as I brought up the consecutive submission issue, he agreed it would probably quickly break.
Thanks for the tip.
The product locked good
https://a.co/d/eJEAw6F
