Hi .
( I can’t find the frequency. I’ve been scanning for a good few days and nothing. )
I am working on NodeMCU V3
ok, the scan was successful
edit
UPS I looked in the sump and there sits AnyQuest Cyble Enhanced, is it the same as EverBlu Cyble Enhanced. the appearance is the same. Only that when I scan it shows me a different frequency each time???
Unfortunately, when added by the helper, the energy meter in the dashboard does not see it
But if I add in config.yaml it shows up.
I cannot enter valid values in a row
will anyone help.
Does the LED go out after reading the value???
It doesn’t go out for me and the next day I don’t want to reach new peaks, I have to manually reset it.
As if suspended.
My LED is also always active but i get data every day based on the scheduler from the code. But its necessary that you read the data one time in order to create the sensor in HA. After that MQTT can do this based on the defined time. Post 18 describes the steps what you need to do. This has worked for me.
Good question, it would be great to be able to read the meter at midnight to produce daily metrics. Any updates on the battery life? Would be also nice to have the device report battery level, it may be asking too much though
08:26:15.290 → Got frequency : 433.791748 ( A travers 3 murs de bétons et 30m plus loin , maison voisine avec jardin entre )
08:26:15.290 → Got frequency : 433.817627 30m
08:26:15.290 → Got frequency : 433.791748 30cm
08:36:37.087 → Got frequency : 433.769775 30cm
08:39:58.978 → Got frequency : 433.770264 30cm
08:41:12.618 → Got frequency : 433.770752 30cm
08:42:45.896 → Got frequency : 433.769775 30cm
08:43:53.248 → Got frequency : 433.769775 30cm
Got frequency : 433.868988 30m
09:57:38.567 ? Got frequency : 433.870850 30m
Got frequency : 433.874023 30m
Got frequency : 433.856628 30m
Got frequency : 433.864990 30m
antenne verte atention inversion du GDo0 et GD02 …stupide …
Got frequency : 433.806976 30m
Got frequency : 433.806000 30m
Got frequency : 433.807376 30 cm
pin 8 (GD02) on antenne => pas besoin . Not need use " pin 8 (GD02) " câble .
I have never succeeded with an ESP32 dev kit 1 wroom 32 espressive.
Work perfect with 8266 .
14h00 My everblue stop transmission for me …
Green antenne is not good . inscription on pcb is not correct . I need change GD00 and GD02 . inversion . after , work perfect . attention avec les ingenieurs chinois … .
Hi, I can see that you solved it but just for other usr. The Soft WDT reset come from the while (42); lines that are after the test and the frequency search. I suppose that they are there to stop the output but ESP8266 needs a delay(x); or a yield(); inside the loop to avoid the watchdog reseting the device.
I have this working with raspberry pi and CC1101…at least two years! I use mqtt to send data to homeassistant.
My data source was the same lamaison…, but I remeber there ware some mistakes that need to be fixed.
Please be aware when trying to communicate of the working hours, usually 6AM-6PM (6H-18H), if you try outside this time it will not anwser!!
Another tihing is that this device has a leak detection warning but I didn’t try ti find which register is the correct one. If anyone need the code I can share…
Hello Alberto,
I am using a PRI 4B with fresh rasbian lite with Mosquitto Broker/Client and RTL_433 / SDR installed.
The MQTT works fine, the RTL_433 too.
