I’m looking for some suggestions for displaying this entity so that it shows the full text of the weather forecast summary. Using simply a standard entity card, seems to cut off the (very large) text and you need to open a sub-window to read it (see below).
The integration is the “Environment Canada” integration which has a large number of sensors for the city/weather station you select when configured.
The entity in question is the sensor.<location_name>_summary that shows a text summary of the forecast for the day.
For example:
Halton Hills Summary
Today. Cloudy with 40 percent chance of showers or drizzle. Wind northwest 30 km/h. Temperature steady near plus 5. UV index 1 or low.
If I use a regular entity card I see the top card in the first screenshot, with extra large text and cut off.
If I use a tile card, it seems to be normal size text, and fits in the window when it spans the screen (second card in first screenshot) but not if I were to use a stacked layout of any sort, then it gets cut off instead of wrapping the text. (see third stacked tile screenshot)
I was able to work out the markdown portion but now I’m curious on your daily forecast card you show above. Is that all done in a markdown card also or is it a custom card of some sort?
@pcwii, Any idea if we can adjust the size of the City/Current Temperature shown here?
I know we can adjust the name text (as you have K-W), but hoping we can actually decrease the size shown. Depending on the screen width, they overlap each other.
