There are a bunch of weather integrations to choose from and everyone youâll ask will have a different opinion about which one to choose. Letâs break down the options where they shine, where they fall short and help YOU choose the perfect fit for your smart home.
So, grab your metaphorical raincoats (or sunscreen, depending on the forecast) and letâs dive in!
Table Of Contents
Why this guide
Feeling overwhelmed by all the weather integrations? Youâre not alone! Inspired by the The Home Assistant Cookbook - Index, I wanted to dive a bit deeper and create a valuable resource to help others.
Beared Thinker made a nice video
which is a good introduction to this guide.
While the original reason for this guide was a change to OpenWeatherMap, letâs focus on the bright side of all the fantastic integrations available in the world of Home Assistant. After all, choice is what makes Home Assistant so great!
This guide is a community effort, so feel free to edit and contribute to keep it up-to-date. This first post can be edited by everyone, so if you spot a mistake or see something is missing, take those 2 minutes to edit the guide.
Introduction
The original list contains the most popular core weather integrations which contain the weather entity providing current weather and weather forecast using public data services. HACS integrations are being added over time which you can help with. Just hit that edit button at the top and add your favorite weather integration.
There are several integrations which I was unable to test. If you got one of them working, please share the results.
Integration list
The following integrations will be covered in this guide:
Core | Signup | Usage | Coverage | Forecast | Distinguishing factor |
AccuWeather | 4.6% | Global | 5 days | Lots of current and forecasted data (air quality, allergies, sun/solar, etc.) | |
AEMET OpenData | <1% | ES | 6 days, 72 hours | Well documented. | |
BuienRadar | None | 2.6% | NL / BE | 5 days | Detailed precipitation forecast, history and radar |
Environment Canada | None | <1% | CA | ? | Gives error. Unable to test |
Meteorologisk | None | 78.9% | Global | 6 days, 24 hours | HA Default integration. Lean and Clean. |
Météo-France | None | 1.8% | FR | 5 days, 24 hours | Documentation might be outdated |
National Weather Service (NWS) | None | 1.7% | US | 7 days, 168 hours | Gives error. Unable to test. |
OpenWeatherMap | Creditcard | 7% | Global | 5 days, 24 hours | Requires credit card |
Open-Meteo | None | 1.2% | Global | 7 days, 168 hours | Extensive forecasts for basic weather info. |
Tomorrow.io | 1% | Global | 6 days, 24 hours | Current air quality, allergies, solar data. Basic forecast for extensive weather info. | |
HACS | |||||
Astro Weather | None | 65 ![]() |
Global | Stargazing condition and forecast | |
Bureau of Meteorology | None | 171 ![]() |
AUS ![]() |
Gives error. Unable to test. | |
Deutscher Wetterdienst | None | 149 ![]() |
DE | Gives error. Unable to test. | |
KNMI | 92 ![]() |
NL | 5 days, 24 hours | Useful entities. Deviates from HA standards | |
IRM KMI | None | 29 ![]() |
NL / BE | 7 days, 48 hours | Allergies, Radar, Weather alert. |
PirateWeather | 327 ![]() |
Global | 8 days, 168 hours | Extensive forecasts extensive weather info. |
The following integrations are not included:
Ambient Weather is not included because it require a physical device.
Wunderground is not included because it require a physical device.
Signup: This column states which data you need to give up in order to use the integration. Integrations which do not require anything can be added without the need for an API key.
Usage: This column describes the popularity of the integration. Quality used to be included as well, but since very few integration have a quality score it doesnât say much.
Refresh interval: Most integrations seems to have a refresh interval of 30 minutes. I havenât found any distinguishing factors here as it might require insight in the code.
Accuracy: Some services choose the closest weather station while others calculate an average based on several nearby weather stations. Note that taking the average of several weather integration might be less accurate.
Attributes
To keep the tables compact and readable, attribute names need to be abbreviated and sometimes combines. The attributes are those defined to be part of the weather entity in Home Assistant. Basic attributes are shown on the weather entity while extra attributes are available in YAML.
abbreviation | attribute | example |
Standard | ||
Con | Condition | Partly cloudy |
Temp | Current temperature or forecasted high | 18.3 °C |
Low | Forecasted low temperature | 9.4 °C |
App | Apparent temperature / feels-like temperature | 21.1 °C |
Dew | Dew point | 6.0 °C |
Hum | Humidity | 76 % |
Rain | Precipitation | 1.5 mm |
Pres | Pressure | 1,016 hPa |
Wind | Wind speed / bearing | 2.3 km/h (NNW) |
Gust | Gust wind speed / bearing | 5.7 km/h (NNW) |
Vis | Visibility | 24.1 km |
Cld | Cloud coverage | 15 % |
O3 | Ozone | 403.3 ppm |
UV | UV Index | 3 |
Nonstandard | ||
Alert | Weather alert | Code yellow |
Rain% | Precipitation chance | 17% |
Text | Detailed textual description | Partly cloudy with moderate chance of rain |
Note: One might notice that precipitation chance is a non-standard attribute. Several integrations offer this data, but it is not a in home assistantâs weather specification. Most people multiply the precipitation chance with the precipitation amount. This might or might not give the right resultsâŠ
Current weather
The weather entity consists of the current weather information captured in the attributes and the daily and optionally hourly forecast.
The weather entity is most commonly used with the weather forecast card or more advanced cards from HACS to display the current and forecasted weather on a dashboard.
Current weather attributes
The table below shows the current weather attribute provided by the weather entity.
Core | Daily | Hourly | Con | Temp | App | Dew | Hum | Rain | Pres | Wind | Gust | Vis | Cld | O3 | UV | Other |
AccuWeather | 5 | - | X | X | X | X | X | X | X | X | X | X | X | |||
BuienRadar | 5 | X | X | X | X | X | X | |||||||||
Meteorologisk | 6 | 24 | X | X | X | X | X | X | ||||||||
Météo-France | 5 | 24 | X | X | X | X | X | |||||||||
NWS | ||||||||||||||||
OpenWeatherMap | 5 | 24 | X | X | X | X | X | X | X | X | ||||||
Open-Meteo | 7 | 168 | X | X | X | |||||||||||
Tomorrow. io | 6 | 24 | X | X | X | X | X | |||||||||
HACS | ||||||||||||||||
IRM KMI | 7 | 48 | X | X | X | X | ||||||||||
KNMI | 5 | 24 | X | X | X | X | X | X | X | X | ||||||
PirateWeather | 8 | 168 | X | X | X | X | X | X | X | X | X |
Rain: One might notice that rain is not part of the current weather data. This is not by accident since rain is very localized and commonly measured on a daily or hourly basis. Therefore it is part of the forecast data in home assistant.
Weather forecast
For more advanced stuff like calculating the amount of water to give your garden the weather.get_forecasts service is useful.
Every integration returns a different set of attributes for hourly and daily forecast.
If you find any mistakes in the table below, please correct them carefully.
Forecast attributes
Attributes can be provided in either the daily and/or hourly forecast. The twice daily forecast is not included since only few integrations use it.
D: Daily
H: Hourly
Core | Daily | Hourly | Con | Temp | Low | App | Hum | Wind | Gust | Rain | Rain% | Pres | Cld | Dew | UV |
AccuWeather | 5 | - | D | D | D | D | D | D | D | D | D | D | |||
BuienRadar | 5 | D | D | D | D | D | |||||||||
Meteorologisk | 6 | 24 | DH | DH | D | DH | DH | D | DH | ||||||
Météo-France | 5 | DH | DH | D | DH | H | D | DH | |||||||
OpenWeatherMap | 5 | 24 | DH | DH | D | DH | DH | DH | DH | DH | DH | DH | DH | DH | |
Open-Meteo | 7 | 168 | DH | DH | D | D | DH | ||||||||
Tomorrow. io | 6 | 24 | DH | DH | D | DH | DH | DH | DH | DH | |||||
IRM KMI | 7 | 24 | DH | DH | D | DH | D | DH | H | ||||||
KNMI | 5 | 48 | DH | DH | D | DH | H | D | |||||||
PirateWeather | 8 | 168 | DH | DH | D | H | DH | DH | DH | DH | DH | H | DH | H | H |
Itâs easy to see why OpenWeatherMap is popular, but since it requires a credit card, I strongly encourage you to look for an alternative.
Extra entities
Some integrations have additional entities such as air quality, allergies information, or sun shine. These can be convenient to use in an automation.
The disadvantage of entities is that the number of entities to provide forecast information can grow rapidly which some users might find messy.
Integration | Entities | Description |
AccuWeather | 129 | Today + 4 day forecast with separate day and night entities. Detailed weather, sun/solar, allergies and air quality |
BuienRadar | 108 | Radar and 5 day forecast for weather and precipitation |
Meteorologisk | 1 | No extra entities |
Météo-France | 11 | Daily precipitation and basic weather |
NWS | ||
OpenWeatherMap | 28 | Basic weather forecast |
Open-Meteo | 1 | No extra entities |
Tomorrow. io | 28 | Current details about weather, solar and allergies |
HACS | ||
IRM KMI | 11 | Radar, Allergies and Weather alarm |
KNMI | 23 | Weather warning and a few useful entities for weather and rain |
PirateWeather | 1 | No extra entities |
Conclusion
Itâs often not about which integration has the most information, but which integration best fit your needs (including privacy). I hope this overview gives you all the information you need to make the best choice for your situation.
Meteorologisk is the default weather integration and an excellent choice for basis weather information and forecast.
Open-Meteo is similar but provides long term forecast for both hourly and daily.
AccuWeather and Tomorrow. io provide a lot of extra entities about sun/solar forecast, allergy data, and air quality.
PirateWeather from HACS has the most extensive weather forecast.
National weather services often have extra data and/or better accuracy.
BuienRadar (NL/BE) rain supreme in precipitation forecast and history.
If this guide was useful to you, leave a
