@briis Is there any way to add lightning strike with distance to lightning strike? I get notifications from the tempest app that there are lightning strikes 10-12 miles away and I see your integration turn a switch on but I would like to be able to create notifications based on how far away the lightning strike was.
OK, Youāre right.
There is a problemā¦ now I can see it.
The problem btw is Node-Red and not my flow: the last update had modified the join node so now it create always an array[8] instead of an array[n] where n is the dimension that I set.
I can modify the flow but if they publish a release that repair the node, the flow donāt work correctly again so I have to think a workaround that works with both cases.
No, at the moment is not possible to filter lightning based on distance I think.
I have to see if there are news on WeatherFlow APIās.
New version available on my GitHub.
This is an MQTT only version: from now Iāll made change (if needed) only in MQTT version of the flow because Iāve removed the Node-Red HACS extension.
Corrected the Join Node problem.
Since I needed the HA entities more than MQTT data, Iāll stay on the old version, that is working fine except for the problem with those 4 values due to the join issue in node-red, and doesnāt require any manual configuration of the sensors in HA.
Since you want to keep only MQTT, did you think about MQTT Discovery? That would let HA create the entities automatically from MQTT data: MQTT Discovery - Home Assistant (home-assistant.io).
Thanks.
Well, if you prefer to remain in that version you can:
- import my new flow without deploy it
- copy change nodes, join nodes and wires for Wind speed, temperature and humidity
- paste them in your flow in the same location
- copy & paste the first function node of each calculation after the join node
- after deploy you should have all calculations run ok
For mqtt discovery Iāll investigate when I have a bit of time
I had to also change the new Dewpoint Calculus: replaced msg.payload
with msg.dp
Seems to be working fine, will tell you in case of problems. Thank you.
In case someone needs it, hereās the code: WF Tempest Node-Red Flow (HA+MQTT) Ā· GitHub
So I am never seeing any debug logging on the UDP side of the flowā¦ Its not clear to me if I am supposed to be configuring the tempest to send to my node-red instance somehowā¦ If that is the case could you please point me towards those steps?
No John, itās a UDP broadcast, basically any host that listens to traffic on that UDP port can get the Tempest data. If broadcast doesnāt work, it might be something related to your network. Do you use a network switch? Do you use VLANs? If HA and Tempes are on the same LAN/VLAN, or better, broadcast domain, you should see the UDP data.
Canāt help more without more information on your setupā¦
this has stopped working in 2021.6.1. Simply says integration smartweatherudp is not availableā¦ nothing in the logs either
reverted back to version 2021.5.4 and all is fine again
edit the manifest.json and had the version string: (there is a pr to do this but itās not been merged). this will fix allow it to be loaded:
Before I spend more time on thisā¦
I am attempting to mimic the WeatherFlow app inside Home Assistant. Due to font sizing, it looks like I will have to make two versions for phone and desktop; I am currently working on a form factor for phone.
This is what I have so far, looking for ideas.
The compass is fully working; I attempted to use the compass card but it does not resize well. This compass is just a selection of images based on direction (taken from other post).
type: picture-elements
image: /local/gauge/Stripe.png
elements:
- type: state-label
style:
top: 8%
left: 30%
box-shadow: null
color: black
font-family: Quicksand
font-size: 300%
background-color: transparent
border-radius: 10%
text-align: center
entity: sensor.temperature
attribute: ''
title: ''
prefix: ''
- type: state-label
style:
top: 5%
left: 70%
box-shadow: null
color: black
font-size: 150%
border-radius: 10%
text-align: center
attribute: ''
title: ''
prefix: 'DewPoint: '
- entity: sensor.wind_direction_avg
style:
left: 10%
top: 50%
width: 10%
type: image
state_image:
'N': /local/WindCompass/N.png
NbE: /local/WindCompass/NbE.png
NNE: /local/WindCompass/NNE.png
NEbN: /local/WindCompass/NEbN.png
NE: /local/WindCompass/NE.png
NEbE: /local/WindCompass/NEbE.png
ENE: /local/WindCompass/ENE.png
EbN: /local/WindCompass/EbN.png
E: /local/WindCompass/E.png
EbS: /local/WindCompass/EbS.png
ESE: /local/WindCompass/ESE.png
SEbE: /local/WindCompass/SEbE.png
SE: /local/WindCompass/SE.png
SEbS: /local/WindCompass/SEbS.png
SSE: /local/WindCompass/SSE.png
SbE: /local/WindCompass/SbE.png
S: /local/WindCompass/S.png
SbW: /local/WindCompass/SbW.png
SSW: /local/WindCompass/SSW.png
SWbS: /local/WindCompass/SWbS.png
SW: /local/WindCompass/SW.png
SWbW: /local/WindCompass/SWbW.png
WSW: /local/WindCompass/WSW.png
WbS: /local/WindCompass/WbS.png
W: /local/WindCompass/W.png
WbN: /local/WindCompass/WbN.png
WNW: /local/WindCompass/WNW.png
NWbW: /local/WindCompass/NWbW.png
NW: /local/WindCompass/NW.png
NWbN: /local/WindCompass/NWbN.png
NNW: /local/WindCompass/NNW.png
NbW: /local/WindCompass/NbW.png
- type: state-label
style:
top: 50%
left: 20%
box-shadow: null
color: black
font-size: 150%
background-color: rtransparent
border-radius: 10%
text-align: center
entity: sensor.wind_bearing_avg
attribute: ''
title: ''
prefix: ''
- type: state-label
style:
top: 50%
left: 35%
box-shadow: null
color: black
font-size: 150%
border-radius: 10%
text-align: center
entity: sensor.wind_speed_avg
attribute: ''
title: ''
prefix: ''
- type: state-label
style:
top: 50%
left: 80%
box-shadow: null
color: black
font-size: 150%
border-radius: 10%
text-align: center
entity: sensor.wind_gust
attribute: ''
title: ''
prefix: 'Gusting: '
@gualandd would it be possible to post the MQTT paths for all the topics on Github? This would be really helpful when setting up the entities in the confi yaml.
(or is there another way than clicking through the entries in Node-RED?)
Thanks!!
Well,
in NR you can open pink nodes (MQTT Out) and copy the Topic path.
If you wish, you can customize the topic path according with your MQTT structure.
Why was the āFeels Likeā temperature removed?
I just updated to 2022.07.7 from 2022.06 and the config I had been using for a long time suddenly showed in C rather than F so I set off to figure out why. Coming to this thread I saw the custom component has moved into HACS and was updated for 2022.07 so I installed it.
Now I have all new sensors, but Feels Like is now missing.
Anybody know why?
thanks
Hi Alex, Danton back again!!
Well, I searching a good system to monitor the weather at home with a good and precise sensor.
What you suggest me? I looking for a FW Tempest, but It has prohibitive prices in Italy!
Do you have any suggestion?
So, Iām looking your post WF Tempest Node-Red Flow (HA+MQTT) Ā· GitHub andā¦ well, you can also check if incoming hail??
Have you test it at home?
Itās very important for me finding hail, in other to enable automatic funcion to āsaveā few components at homeā¦
I have the WF Tempest, the Wittboy (Ecowitt WittBoy GW2001 - Meteo-Project - Vendita e Installazione Stazioni meteo e Webcam) and also a Davis station that I didnāt mount yet.
Didnāt frankly check if hail is detected, you should check the docs about this. Iāll see if there are specific sensors for that.
Thank you Alex!
How do you find this device? Does it work well and/or is it accurate enough in determining the weather?
Reading through your code that I posted earlier, I saw that there is also a hail control (line 364), and I thought it was tested, not to bring you bad luck, of course.
I hope it never hails, but in case it does, it would be useful to activate some automatic functions, such as closing the blinds, opening the pool cover, etc.
