I have an old iPad 1 (the original model! :)) laying around, that I was planning to mount on the wall to access my HASS installation.
However, the web UI does not work. When I go to the page, I see the blue HASS icon splash screen, but then nothing happens.
I presume the problem lies in the old Safari. iPad 1 cannot be upgraded beyond iOS 5.1.1
I tried turning on the Safari debug console, which claims there are two JS errors: “TypeError: ‘undefined’ is not an object”. Unfortunately, there are no line numbers or anything to pinpoint the problem further. I do not even know if this javascript issue is what’s causing the blank page.
As a workaround, I tried to download Chrome. It did not work either (I was redirected to an old outdated version of Chrome), and it had even less debugging capabilities.
Any idea how to proceed? Can I turn down the amount of JS in the web page? How can I debug Safari issues on an old iPad?
Thanks! I just recently discovered this. I do need to verify that hadashboard works with iOS 5.1.1, but if it does it actually looks more suitable. A bit more work to setup, though.
I’m still curious to why it does not work, though. I found on the forum that similar behaviour was displayed by other browsers as well (see e.g. HASS hangs on web browser)
I’ll try to do some debugging and see if I can trace what is causing this.
I haven’t got anything that old, but it works on iOS7. If you fire one of the iPads up, you can try and see if Dashing works here: http://dashingdemo.herokuapp.com/sample. If it does, I think the dashboard should work too.
If I’m correct the default HA UI works with iOS 7.1+. This is because of the technique used for the UI (Polymer) which is supported from that platform onwards.
I think the current UI could be made to work on older devices if the UI loads Polyfill when an older browser is used. But that requires a change on the front end code.
