Weber iGrill 2 integration with Lovelace UI
Thanks for that. House maintenance day today but I should be able to give that a shot tomorrow night!
no need to thank me, you did all the work, I just combines the sensors :wink:
i am a little stuck…
  • I installed all the requirements
  • got the monitor.py running
but all it shows is ā€œ2020-05-09 10:43:00,354 MainThread INFO: log_level set to: INFOā€
and nothing else after that, what do i need to do?
do i need to connect the igrill to my pi through Bluetooth setup? i tried but cant do it.
running pi3b (python 2.7.16) and igrill2
I am sure its the Bluetooth connection to the igrill, the blue light stops blinkimg when i start monitor.py, but starts blinking again soon.
OK got it going… tried a different pi, turned bluetooth on and off, then it worked. sweet project thanks.
Seems to work a treat. Thank you!
Followed @war1000’s guide, on a RPi 3B, however just doesn’t seem to work.
Initially getting connect/disconnects on the MQTT side of hass.io, so made it anonymous. That seemed to solve that, however the BT LED on the iGrill2 seems to go solid for a bit, then flashing.
Can’t get my head around why it’s not staying connected to the Pi
./monitor.py -l debug stops at ā€œSending key of all 0’sā€ - could that be an issue?
Have cleared the iGrill from my phone BT.
Tried the suggestions at https://github.com/bendikwa/igrill#troubleshooting, AutoEnable was already true, and the second line wasn’t there in /lib/udev/rules.d/90-pi-bluetooth.rules.
Thoughts?
EDIT:
Started again from scratch, gave it its own MQTT username/password. Now get this on Mosquitto:
1589791583: New client connected from 192.168.1.106 as auto-756F5485-8508-428A-1776-0495E170165A (p2, c1, k40, u'igrillbridge').
1589791607: New connection from 192.168.1.106 on port 1883.
1589791607: New client connected from 192.168.1.106 as auto-221EEAE6-7ABA-6B55-1799-ADE2FCE35F6C (p2, c1, k40, u'igrillbridge').
1589791644: Client auto-756F5485-8508-428A-1776-0495E170165A has exceeded timeout, disconnecting.
from ./monitor.py -l debug:
pi@raspberrypi:~/igrill $ ./monitor.py -l debug
2020-05-18 09:50:21,673 MainThread INFO: log_level set to: debug
2020-05-18 09:50:21,673 MainThread DEBUG: initialized with source=., defaultdata={'mqtt': {'host': 'localhost'}}
2020-05-18 09:50:21,675 MainThread DEBUG: Reading ./device.yaml, ./mqtt.yaml
2020-05-18 09:50:21,686 MainThread DEBUG: YAML LOAD: {'devices': [{'topic': 'bbq', 'interval': 20, 'type': 'igrill_v2', 'name': 'igrill', 'address': '70:91:8F:0D:B8:CF'}]}
2020-05-18 09:50:21,696 MainThread DEBUG: YAML LOAD: {'mqtt': {'host': 'droperidol', 'port': 1883, 'auth': {'username': 'igrillbridge', 'password': 'xxxx'}, 'keepalive': 40}}
2020-05-18 09:50:21,697 MainThread DEBUG: Validating dict {'mqtt': {'host': 'droperidol', 'port': 1883, 'auth': {'username': 'igrillbridge', 'password': 'xxxx'}, 'keepalive': 40}, 'devices': [{'topic': 'bbq', 'interval': 20, 'type': 'igrill_v2', 'name': 'igrill', 'address': '70:91:8F:0D:B8:CF'}]} with specs: {'required_entries': {'mqtt': <type 'dict'>, 'devices': <type 'list'>}}
2020-05-18 09:50:21,698 MainThread DEBUG: Validating dict {'host': 'droperidol', 'port': 1883, 'auth': {'username': 'igrillbridge', 'password': 'xxxx'}, 'keepalive': 40} with specs: {'optional_entries': {'tls': <type 'dict'>, 'port': <type 'int'>, 'auth': <type 'dict'>, 'keepalive': <type 'int'>}, 'required_entries': {'host': <type 'str'>}}
2020-05-18 09:50:21,698 MainThread DEBUG: Validating dict {'username': 'igrillbridge', 'password': 'xxxx'} with specs: {'optional_entries': {'password': <type 'str'>}, 'required_entries': {'username': <type 'str'>}}
2020-05-18 09:50:21,698 MainThread DEBUG: Validating list [{'topic': 'bbq', 'interval': 20, 'type': 'igrill_v2', 'name': 'igrill', 'address': '70:91:8F:0D:B8:CF'}] with specs: {'specs': {'list_type': <type 'dict'>, 'optional_entries': {'publish_missing_probes': <type 'bool'>, 'missing_probe_value': <type 'str'>}, 'required_entries': {'topic': <type 'str'>, 'interval': <type 'int'>, 'type': <type 'str'>, 'name': <type 'str'>, 'address': <type 'str'>}}}
2020-05-18 09:50:21,699 MainThread DEBUG: Validating dict {'topic': 'bbq', 'interval': 20, 'type': 'igrill_v2', 'name': 'igrill', 'address': '70:91:8F:0D:B8:CF'} with specs: {'list_type': <type 'dict'>, 'optional_entries': {'publish_missing_probes': <type 'bool'>, 'missing_probe_value': <type 'str'>}, 'required_entries': {'topic': <type 'str'>, 'interval': <type 'int'>, 'type': <type 'str'>, 'name': <type 'str'>, 'address': <type 'str'>}}
2020-05-18 09:50:21,734 igrill DEBUG: Device thread igrill (re)started, trying to connect to iGrill with address: 70:91:8F:0D:B8:CF
2020-05-18 09:50:21,735 igrill DEBUG: Created new device with name igrill
2020-05-18 09:50:21,735 igrill DEBUG: Trying to connect to the device with address 70:91:8F:0D:B8:CF
2020-05-18 09:50:21,736 igrill DEBUG: Calling btle.Peripheral.__init__ with lock: 1993315584
2020-05-18 09:50:21,747 igrill DEBUG: Failed to connect to peripheral 70:91:8F:0D:B8:CF, addr type: public
2020-05-18 09:50:21,747 igrill DEBUG: Sleeping for 20 seconds before retrying
2020-05-18 09:50:41,768 igrill DEBUG: Device thread igrill (re)started, trying to connect to iGrill with address: 70:91:8F:0D:B8:CF
2020-05-18 09:50:41,769 igrill DEBUG: Created new device with name igrill
2020-05-18 09:50:41,769 igrill DEBUG: Trying to connect to the device with address 70:91:8F:0D:B8:CF
2020-05-18 09:50:41,770 igrill DEBUG: Calling btle.Peripheral.__init__ with lock: 1993315584
2020-05-18 09:50:41,790 igrill DEBUG: Failed to connect to peripheral 70:91:8F:0D:B8:CF, addr type: public
2020-05-18 09:50:41,791 igrill DEBUG: Sleeping for 20 seconds before retrying
2020-05-18 09:51:01,812 igrill DEBUG: Device thread igrill (re)started, trying to connect to iGrill with address: 70:91:8F:0D:B8:CF
2020-05-18 09:51:01,813 igrill DEBUG: Created new device with name igrill
2020-05-18 09:51:01,813 igrill DEBUG: Trying to connect to the device with address 70:91:8F:0D:B8:CF
2020-05-18 09:51:01,814 igrill DEBUG: Calling btle.Peripheral.__init__ with lock: 1993315584
2020-05-18 09:51:01,834 igrill DEBUG: Failed to connect to peripheral 70:91:8F:0D:B8:CF, addr type: public
2020-05-18 09:51:01,835 igrill DEBUG: Sleeping for 20 seconds before retrying
then suddenly:
2020-05-18 09:56:42,507 igrill DEBUG: Device thread igrill (re)started, trying to connect to iGrill with address: 70:91:8F:0D:B8:CF
2020-05-18 09:56:42,508 igrill DEBUG: Created new device with name igrill
2020-05-18 09:56:42,508 igrill DEBUG: Trying to connect to the device with address 70:91:8F:0D:B8:CF
2020-05-18 09:56:42,509 igrill DEBUG: Calling btle.Peripheral.__init__ with lock: 1993315584
2020-05-18 09:56:42,814 igrill DEBUG: Releasing lock: 1993315584
2020-05-18 09:56:45,148 igrill DEBUG: Authenticating...
2020-05-18 09:56:45,149 igrill DEBUG: Sending key of all 0's
2020-05-18 09:56:45,480 igrill DEBUG: Authenticated
2020-05-18 09:56:45,483 igrill DEBUG: Added probe with index 1, name PROBE1_TEMPERATURE, and UUID Characteristic <06ef0002-2e06-4b79-9e33-fce2c42805ec>
2020-05-18 09:56:45,485 igrill DEBUG: Added probe with index 2, name PROBE2_TEMPERATURE, and UUID Characteristic <06ef0004-2e06-4b79-9e33-fce2c42805ec>
2020-05-18 09:56:45,487 igrill DEBUG: Added probe with index 3, name PROBE3_TEMPERATURE, and UUID Characteristic <06ef0006-2e06-4b79-9e33-fce2c42805ec>
2020-05-18 09:56:45,489 igrill DEBUG: Added probe with index 4, name PROBE4_TEMPERATURE, and UUID Characteristic <06ef0008-2e06-4b79-9e33-fce2c42805ec>
2020-05-18 09:56:46,507 igrill DEBUG: Published temp: {1: 24.0, 2: False, 3: False, 4: False} and battery: 59.0 to topic bbq/igrill
2020-05-18 09:56:46,507 igrill DEBUG: Sleeping for 20 seconds
2020-05-18 09:57:06,530 igrill DEBUG: Device disconnected
2020-05-18 09:57:06,531 igrill DEBUG: Sleeping for 20 seconds before retrying
2020-05-18 09:57:26,552 igrill DEBUG: Device thread igrill (re)started, trying to connect to iGrill with address: 70:91:8F:0D:B8:CF
2020-05-18 09:57:26,553 igrill DEBUG: Created new device with name igrill
2020-05-18 09:57:26,553 igrill DEBUG: Trying to connect to the device with address 70:91:8F:0D:B8:CF
2020-05-18 09:57:26,554 igrill DEBUG: Calling btle.Peripheral.__init__ with lock: 1993315584
2020-05-18 09:57:26,825 igrill DEBUG: Releasing lock: 1993315584
2020-05-18 09:57:27,155 igrill DEBUG: Device disconnected
2020-05-18 09:57:27,155 igrill DEBUG: Sleeping for 20 seconds before retrying
But it stopped again, and went back to disconnected/sleeping loop.
Tried it with a fresh SD card of Raspbian (not Lite) - pairing via the desktop just times out, but the blue light on the iGrill2 goes solid.
So the line in the troubleshooting section is:
ACTION=="add", SUBSYSTEM=="bluetooth", KERNEL=="hci[0-9]*", RUN+="/bin/hciconfig %k up"
whereas mine was:
ACTION=="add", SUBSYSTEM=="bluetooth", KERNEL=="hci[0-9]", TAG+="systemd", ENV{SYSTEMD_WANTS}+="bthelper@%k.service"
Commented it out anyway and it seems to be working now, after a few restarts of the Pi and the iGrill2!
Has anyone else passed sensor values through to Google Assistant?
I’ve rebuilt a few times and even ordered a new pi zero. Is anyone successfully running this on a zero w?
I plan to give it another crack, as the BT range on my iGrill is less than I need, so would love to get it working with HA.
I’m going to test this on the weekend, can give you some feedback on my progress if you like.
I have managed to install the Igrill integration on new dedicated Pizero with monitor.py running continuously. Seems to be working very stable. As soon as I power on my Igrill2 its reconnected to Pizero via BT and starts to pass on values via wifi/mqtt to my HA running on a PI-4, even when the Igrill2 may have been offline for a week or so.
Just trying to figure out a good way to monitor that the pizero is in a good health - I have considered glances but seems to be quite cpu intensive on a pi-zero.
I just installed it on a Pi Zero W. Here’s a quick quide how I did it:
Install required packages:
sudo apt-get update && upgrade
sudo apt install git python3-pip
Clone Repo:
git clone https://github.com/bendikwa/igrill.git
Install iGrill Requirements:
pip3 install -r igrill/requirements.txt
Create config dir:
mkdir igrill/config
Create MQTT config file:
nano igrill/config/mqtt.yaml
Add the following:
mqtt:
  host: ip-of-mqtt-server
  port: 1883
  keepalive: 60
  auth:
    username: 'username'
    password: 'password'
Turn on the iGrill device and get the MAC address with:
sudo hcitool lescan
Create Device config file:
nano igrill/config/device.yaml
Add the following:
devices:
  - name: 'Kugelgrill'
    type: 'igrill_v2'
    address: 'AB:12:CD:34:EF:56'
    topic: 'temperatur/grill'
    interval: 20
Start app:
igrill/monitor.py -c igrill/config
You should now see the values getting published to the topic ā€˜temperatur/grill’.
To continually run the app as a service in the background, create a file called igrill.service:
sudo nano /etc/systemd/system/igrill.service
Add the following content:
[Unit]
Description=igrill MQTT service
After=network.target
[Service]
Type=simple
Restart=always
RestartSec=2
User=pi
ExecStart=/usr/bin/python /home/pi/igrill/monitor.py -c /home/pi/igrill/config
[Install]
WantedBy=multi-user.target
Test the service:
sudo systemctl start igrill
sudo systemctl status igrill
Restart the service:
sudo systemctl stop igrill
sudo systemctl restart igrill
Enable service to run on boot:
sudo systemctl enable igrill
sudo reboot now
I get the following error when trying to run the igrill app:
pi@raspberrypi:~ $ igrill/monitor.py -c igrill/config
  File "igrill/monitor.py", line 8, in <module>
    from config import Config
  File "/home/pi/igrill/config.py", line 1, in <module>
    from builtins import object
ImportError: No module named builtins
did you install the requirements?
What does pip3 list show?
$ pip3 list
Package       Version
asn1crypto    0.24.0
bluepy        1.3.0
certifi       2018.8.24
chardet       3.0.4
cryptography  2.6.1
entrypoints   0.3
future        0.17.1
idna          2.6
keyring       17.1.1
keyrings.alt  3.1.1
paho-mqtt     1.4.0
pip           18.1
pycrypto      2.6.1
PyGObject     3.30.4
python-apt    1.8.4.1
pyxdg         0.25
PyYAML        5.1.2
requests      2.21.0
SecretStorage 2.3.1
setuptools    40.8.0
six           1.12.0
ssh-import-id 5.7
urllib3       1.24.1
wheel         0.32.3
yamlreader    3.0.4
I also notice when looking further up into the install of the requirements text, the following error. Have several:
The scripts futurize and pasteurize are installed in ā€˜/home/pi/.local/bin’ which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
What do you get when you enter python --version? It should be something with 3.xx
I have rasperry pi running hassos. I would like to have this running on the same device. What is the best way to get this running?
It’s showing version 2.7.6??
I’m going to start over again and make sure I use pip3 for everything.
That’s why it’s not working, it’s using the wrong python version. No need to start over.
This command should fix it.
sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.7 1
That seems to work! Thank you. Now I just need to figure out how to get the MQTT readings, as they’re not showing up. Is my formatting of my mqtt.yaml correct?
mqtt:
  host: 192....
  port: 1883
  keepalive: 60
  auth:
    username: 'igrill'
    password: 'XxXxXxXx'
Your formatting is correct.
Do you have a user ā€˜igrill’ configured in your mqtt broker?
By the way, you don’t need to hide this ip-address as it is a local ip address, no one can get access to your network through this
