Weber iGrill 2 integration with Lovelace UI
Below is a screenshot of my integration with Weber iGrill 2 into the Lovelace UI. I used the code from https://github.com/bendikwa/igrill.git to create the MQTT integration between the igrill and a raspberry pi 3. I run this code on a different raspberry pi than my Home Assistant so that I can move it around closer to the smoker for bluetooth connectivity. I already had mosquitto running on my Home Assistant instance so I just pointed the client on the new instance to that. I then created some alerts to tell me if my smoker’s ambient temperature goes out of a set range, as well as, alerts to notify me when a given probe crosses a set threshold. Nothing fancy, but I am no longer tethered to bluetooth range to keep an eye on my Traeger.
I was looking for something exactly like this, so thank you.
Nice use off Lovelace. I’ll be doing something similar once I get my Maverick grill thermometer working again with the RTL 433mhz stick and addon
Nice :slight_smile:
Could you share your automation, etc etc?
configuration.yaml
          - platform: mqtt
            state_topic: "bbq/grill/probe1"
            qos: 0
            unit_of_measurement: "°F"
          - platform: mqtt
            state_topic: "bbq/grill/probe2"
            qos: 0
          - platform: mqtt
            state_topic: "bbq/grill/probe3"
            qos: 0
          - platform: mqtt
            state_topic: "bbq/grill/probe4"
            qos: 0
          - platform: mqtt
            state_topic: "bbq/grill/battery"
            qos: 0
            unit_of_measurement: "%"
        sensors:
          grill_alert_temp:
            value_template:
              '{% if (states.sensor.probe_4.state | int) < (states.input_number.grill_alert_low.state | int) or (states.sensor.probe_4.state | int)  > (states.input_number.grill_alert_high.state | int) %}
                Alert
              {% else %}
                Normal
              {% endif %}'
            friendly_name: Grill Temp Alert
        sensors:
          target_alert_temp_probe_1:
            value_template:
              '{% if (states.sensor.probe_1.state | int) >= (states.input_number.grill_probe_1_target.state | int) %}
                Alert
              {% else %}
                Normal
              {% endif %}'
            friendly_name: Probe 1 Target Alert
        sensors:
          target_alert_temp_probe_2:
            value_template:
              '{% if (states.sensor.probe_2.state | int) >= (states.input_number.grill_probe_2_target.state | int) %}
                Alert
              {% else %}
                Normal
              {% endif %}'
            friendly_name: Probe 2 Target Alert
        sensors:
          target_alert_temp_probe_3:
            value_template:
              '{% if (states.sensor.probe_3.state | int) >= (states.input_number.grill_probe_3_target.state | int) %}
                Alert
              {% else %}
                Normal
              {% endif %}'
            friendly_name: Probe 3 Target Alert
    input_number:
        grill_alert_low:
        name: Grill Low Temp
        initial: 150
        min: 100
        max: 500
        step: 5
      grill_alert_high:
        name: Grill High Temp
        initial: 340
        min: 100
        max: 500
        step: 5
      grill_probe_1_target:
        name: Probe 1 Target Temp
        initial: 160
        min: 60
        max: 250
        step: 1
      grill_probe_2_target:
        name: Probe 2 Target Temp
        initial: 160
        min: 60
        max: 250
        step: 1
      grill_probe_3_target:
        name: Probe 3 Target Temp
        initial: 160
        min: 60
        max: 250
        step: 1
automations.yaml
    - alias: "Monitor Grill Temp Alert"
        - platform: state
          entity_id: sensor.grill_alert_temp
          to: 'Alert'
        - service: notify.ios_notify
            message: "Grill temp outside limits. Currently {{ states.sensor.probe_4.state }} F"
    - alias: "Monitor Grill Temp Normal"
        - platform: state
          to: 'Normal'
            message: "Grill temp within limits. Currently {{ states.sensor.probe_4.state }} F"
    - alias: "Probe 1 Target Temp"
        - platform: state
          entity_id: sensor.target_alert_temp_probe_1
          to: 'Alert'
            message: "Probe 1 has reached the target temp. Currently {{ states.sensor.probe_1.state }} F"
    - alias: "Probe 2 Target Temp"
        - platform: state
          entity_id: sensor.target_alert_temp_probe_2
          to: 'Alert'
            message: "Probe 2 has reached the target temp. Currently {{ states.sensor.probe_2.state }} F"
    - alias: "Probe 3 Target Temp"
        - platform: state
          entity_id: sensor.target_alert_temp_probe_3
          to: 'Alert'
            message: "Probe 3 has reached the target temp. Currently {{ states.sensor.probe_3.state }} F"
ui-lovelace.yaml
    - icon: mdi:pig
        title: iGrill
        cards:
          - type: vertical-stack
            cards:
             - type: weather-forecast
               entity: weather.openweathermap
             - type: entities
               show_header_toggle: true
               title: Weber iGrill
               entities:
                 - entity: sensor.probe_1
                   secondary_info: last-changed
                 - entity: sensor.probe_2
                 - entity: sensor.probe_3
                 - entity: sensor.probe_4
                 - entity: sensor.igrill_battery
          - type: horizontal-stack
            cards:
             - type: custom:gauge-card
               title: Probe 1
               min: 0
               max: 350
               severity:
                 red: 190
                 green: 65
                 amber: 0
               title: Probe 2
               min: 0
               max: 350
               severity:
                 red: 190
                 green: 65
                 amber: 0
            cards:
               title: Probe 3
               min: 0
               max: 350
               severity:
                 red: 190
                 green: 65
                 amber: 0
               title: Probe 4 (Ambient)
               min: 0
               max: 425
               severity:
                 red: 300
                 green: 90
                 amber: 0
    - type: history-graph
            title: 'History'
            entities:
              - sensor.probe_1
              - sensor.probe_2
              - sensor.probe_3
              - sensor.probe_4
          - type: entities
            title: iGrill info
            entities:
              - input_number.grill_alert_low
              - input_number.grill_alert_high
              - sensor.grill_alert_temp
              - input_number.grill_probe_1_target
              - sensor.target_alert_temp_probe_1
              - input_number.grill_probe_2_target
              - sensor.target_alert_temp_probe_2
              - input_number.grill_probe_3_target
              - sensor.target_alert_temp_probe_3
              - automation.monitor_grill_temp_alert
              - automation.monitor_grill_temp_normal
              - automation.probe_1_target_temp
              - automation.probe_2_target_temp
              - automation.probe_3_target_temp
This is really nice. I have a plugin for the FireBoard with HomeSeer but no graphic dashboard like this. I wonder if I can integrate HomeSeer and Home Assistant for a dashboard use case? Thoughts are flowing :slight_smile:
Anybody any luck with getting the integration to work?
After changing a few hard-coded items (e.g. the MAC address of the iGrill 2 device) I still can’t get it to run - this is the current error message:
2018-08-06 19:34:58,650 MainThread INFO: log_level set to: INFO
  File "./monitor.py", line 51, in <module>
    main()
  File "./monitor.py", line 27, in main
    client = mqtt_init(config['mqtt'])
  File "/home/pi/igrill/utils.py", line 50, in mqtt_init
    mqtt_client.connect(**strip_config(mqtt_config, ['host', 'port', 'keepalive']))
  File "/home/pi/igrill/utils.py", line 100, in strip_config
    return {k: v for k, v in config.iteritems() if k in allowed_keys and v}
AttributeError: 'dict' object has no attribute 'iteritems'
i got it working over the weekend but it wasn’t as straight forward as i had hoped.
are you running monitor.py or monitor_igrill_v2.py?
i couldn’t get the monitor.py to work, so i reverted to monitor_igrill_v2.py and just updated the script manually
Hmmmm…I have it working with monitor.py, did you pull the enable_threading branch. I tried several different forks from that repo and the one I linked seem to work the best.
Is the mqtt.yaml config correct syntax ? Did you put the location of your broker in there?
Ya I kept getting weird errors but it is probably something dumb I did on my end.
I’m inclined to leave it alone now though.
I am using the enable_threading branch, I changed:
  1. #!/usr/bin/env python in monitor.py to #!/usr/bin/env python3
  2. ADDRESS and mqtt_server in monitor_igrill_v2.py
  3. mqtt.yaml to show my host IP and port for my mqtt server
3 shouldn’t have been nexessary, I think, because the mqtt info is hardcoded in the file monitor_igrill_v2.py anyway
But the error messages above are still what I get :frowning:
I think is uses the hard coded values if it doesn’t find a config file.
I ran into issues trying to run in with python 3. One other person I exchanged messages said he had issues running it with Jessie, so he updated to stretch
Thanks for the hint - I have another Pi3 running on stretch, I will try it on that one.
Now that I think of it, that error you are having is the last error I got when trying to run it with python 3. I fixed a couple along the way, but then got this one, and said forget it, I will run it with python 2:
First time poster, fairly new HA user. When I run haas --script check config on both the configuration.yaml and ui-lovelace yaml, I am getting the error Component not found: igrill. Any idea what I am missing?
There really is no component called igrill, can you included the relevant portions of your config.yaml and ui-lovelace and I will take a look.
I do have a group setup, but that shouldn’t impact unless you reference it somewhere, I don’t think I reference it, but just in case here is what I have, in my groups.yaml:
igrill:
    entities:
      - sensor.probe_1
      - sensor.probe_2
      - sensor.probe_3
      - sensor.probe_4
      - sensor.igrill_battery
Well, I’m not sure what it was. I added the Group and was getting the same issue. I then redid the complete configuration.yaml and while it appears to be identical, something must have been “off”. It works with and without the Group, so I’m not sure what was going on. (copied out to Notebook ++ and then pasted back) :man_shrugging:
For the record, I’ll be modifying this for my Ivation sensor (433 mHz) and my existing python script using rtl_433 that sends MQTT info.
Cool!!! Glad you got past that error.
