Webhook Error 127.0.0.1
Since upgrading to HA 116.4, the log file has been filled with an error related to webhooks. The error reads;
Received message for unregistered webhook 58890927bc14aeb7cac9542e5a20aa481294e0ae7298fab770fac8bc2b3c9171 from 127.0.0.1
Following several suggestions found in the the forums, I searched for the SmartThings integration. It doesn’t seem to exist. I expanded logging for webhooks to include debug data but no information, other than the error, shows up in the logs. Can anyone shed light on why I’m seeing this error and how I might go about resolving it?
With appreciation
Similar pbm for me. You can search for the integrations using WebHook:
IFTTT, GitHub, Telegram, …
I think my pbm comes from HA Cloud. probably because I used 2 different Pi to connect.
Searching how to get access to the associated WebHook.
Hope this helps,
V.
Log entries indicate “Remote Access” for HA may be my issue. When remote access is enabled, the errors occur. When disabled there’s no errors. I’m using development release 5.4 (HA OS 5.4). Which version are you using?
Same version, latest update as I’m setting up the configuration.
I evaluate the use of Home Assistant Cloud.
