Hello there,
Isn’t time to recreate an open discussion about mesh wifi in 2024?
Of course I’ve searched into the forum already but, you know, technology is so not static.
I read this thread
But I’m looking over the Internet for 2 weeks now and I’m struggling.
Like the OP of the linked post, my ISP WiFi is a mess. 6 meters away from my box, same floor, through one plasterboard wall, it is not detected and/or disconnect all the time.
Therefore, I’m thinking of a good wifi mesh network.
And here I am with my questions/requirements:
- I’ve some Fujitsu AC, Somfy covers and some other equipments that only accept 2.4GHz bandwith and sometimes only on some specific chanel(s) so I need a way to enable that 2.4GHz (maybe as a separated SSID?) and select the chanel if needed
- I’d need to have the Ethernet and WiFi devices to share the same LAN without adding route (means the mesh devices should only operate on the first 2 layers of the network stack: physical and data link, not network).
- Parental control is a plus but I can live without it if it is not free.
- Ethernet backhaul would be highly appreciated
- My ISP is providing 2 ways to replace their hardware with a private router:
Set the Internet Box in Bridge mode but then there is a warning : “You create 2 separate networks. One on the Internet Box and one on your own router. Devices connected to one network cannot communicate with devices on the other. We strongly recommend that you disable WiFi on the Internet Box and reconnect all your devices behind your router. Remember: the TV Box, VoIP and our WiFi Booster will not work behind a private router.”
Remove completely the Internet Box and replace with my own router but it MUST support VLAN tag over WAN to do that.
I already had a look at Tenda and TP-Link Deco X60.
Something to note, my ISP speed is 500/500Mbps so no need to be crazy of Gigabit, 2.5Gbits and such but a good backhaul is required to not lose the power of meshing.
Talking about backhaul, I’ve a secondary question:
Should I connect the mesh devices together (using CPL) or all to the box (also via CPL)? In other words, who is doing the backbone of the network : the box between its ethernet ports or the mesh devices together?
Sorry, it is long post, thank you if you read up to here, hope you can advice me and others
P.S.: My HA configuration is super basic : Core, no VM, no Docker, nothing fancy just a Raspberry Pi with Core installed.
EDIT
I realise, reading my post that point 2 and 5 seems to oppose each other. It is. But the idea is, I’d prefer to keep the ISP Internet Box for the ethernet part and the connection to the TV, the NAS or the media players and fullfill point 2 (same LAN) but if needed then I can remove the box and use the ethernet port of the mesh devices (usually there are 2 or 3 on each) and that is the idea beyond point 5.
