What smoke detectors are recommended?
Hi all,
Currently i have a combination with Fibaro controller and several z-wave devices. I would like to start over and switch to Home Assistant later this year. For now i need to replace my smoke detectors (Fibaro Smoke detectors) and would like to know what is recommended to use with HA.
I would like if the smoke detectors are able to connect to each other and are fully operational withouth Home Assistant for dectecting fire.
What is recommended? I looked at the Nest smoke detecotrs, but it seems that they do not work out of the box with HA, is it a lot work to get them working? Or are there better options available?
Any help is appriciated.
Kind regards,
Roland
I’m currently using the First Alert Battery Powered Z-Wave Smoke Detector & Carbon Monoxide Alarm, 2nd Generation with HA. East setup, loads all the entities, even loads some button where I do not need to reach the detector to reset the alarm, I can do that from HA dashboard.
I have about a dozen and while I’m perfectly happy with them as smoke detectors (got them years before HA), the integration with HA is lacking and doesn’t seem to really be actively maintained (plus it’s not local). I don’t plan to ever replace them though, until they ‘expire’.
I can across Bosch Rookmelder II which I will test.
I have Nest Protect but considering how Google has basically left them on life support only when they expire in 5 years (replace your smokes every 10 years. The detection media does have a end of life) I’m not putting in more protects. Instead I’m putting garden variety Wired CO/smoke detectors and Adding a ZWave relay to the wired detector loop. (most of the vendors that make ZWave smokes also make relays
Hardwired with battery backup, cross alert capable ND HA gets the signals.
I definitely agree with Nathan. Someone posted this device on another thread recently that connects to the common communication wire of standard hardwired detectors to make them smart, and it looks interesting.
Thanks for all the answers. I am stil in doubt. I do not want to hack into the smoke detoctor, so for me i am looking into the first alert smoke detectors. And i found some others from XSense and Netatmo i am looking into.
if there are more suggestion, please post. Thanks again.
I have a zwave smoke/CO alarm listener which is a battery-powered device that sits next to any alarm and will listen for the unique smoke or CO alarm and provides a binary sensor for each that you can trigger automations off.
The positives:
  • it doesn’t physically connect to your smoke/CO alarm and therefore can’t interfere with their function
  • you can use any smoke/CO alarm you want, wired or wireless
The negatives:
  • some have said it isn’t 100% reliable, although I have never had an issue during testing or when smoke has actually been detected. To enable reliable CO sensor listening you have to change a setting on it, and I suspect some people who complain haven’t done that.
That said, now that Zooz offers the detector listed above, I may add that to my setup just for an extra bit of reliability/redundancy.
The downside to the wired options (either the Zooz option or using relays with dry contact sensors) are:
  • it requires hardwired and interconnected smoke/CO detectors
  • it only works when power is available to the smoke/co sensor. When power goes out, your smoke/co sensors will function on their backup battery but the relays and Zooz sensors won’t function.
Is Z-wave a requirement? Or is Zigbee acceptable?
If Zigbee is an option, I can share that I recently bought two Schneider Wiser W599001 smoke detectors. These met all of my requirements:
  • Connect to Home Assistant
  • Work perfectly even if Home Assistant is offline (by this I mean that both alarms sound if one is triggered, without depending on Home Assistant running - they have an independent radio connection)
  • Don’t need a special hub to configure or use (they connect directly to Home Assistant via Zigbee/ZHA, without the Schneider Wiser hub)
These are battery powered, but there exist some similar ones that run off mains power.
Hi Tim, these sound good. Where did you purchase them? I can’t find a supplier for them in the UK, or the EU for that matter. Thanks, Barry
It’s from the smartesthouse. US and UK/EU zwave frequencies are different though.
They do list EU frequency devices for sale
Not sure if this detector addon is available in EU frequency- you can try emailing thir support if you don’t see it on the website at [email protected]
“Hack into the smoke detector”? Look at how you hard wired devices are alredu installed. There should be a box ath AC power and the third wire. Then there are wire nuts and a plug that is custom to your brand of detector. Thisis they way it has been done for 40+ years, at least here in California and it has beed required by code in all new construction.
The Zooz z-wire gets place inside the ectrical box and is wired in parallel to the existing setup. It is installed electricaly as it it were o=another detector in the same box. You remove those wire nuts and all the zooz box then replace the wire nuts.
They’re available from many suppliers here in Sweden
 m.nu, elbutik.se, Hornbach, Bauhaus, Amazon.se
 If you’re in the UK, perhaps they’re not certified for the UK market?
Did you find a UK supplier in the end. I’m interested in these. Thanks @mwav3 for suggestion!
There is s a Schneider Wiser W599002 smoke detector available on amazon uk for £90(!) with £40(!!!) delivery
thinking there must be a more cost effective source!
Has anyone tried the Kidde Smart Smoke & Carbon Monoxide Detector? Looking for seamless integration in HA obviously. Im OK withe HACS, but would prefer standard.
Are there smart devices with all functions ?
Smoke Detector, Wifi AP/repeater, Zigbee repeater, Presence detector, Temp, sound sensor etc etc
I want a smoke detector/alarm on all places where wifi should work in my house and don’t like many devices everywhere.
sheers Harjan
Man, you would hope. It seems like this is an untapped market, especially when you have wired AC power in a lot of newer homes. You could have a device that does smoke, carbon monoxide, air quality, wifi AP, Thread border router, camera, motion, and path light. So many of these existing detectors are battery only, it is baffling that someone hasn’t come up with a device that does it all off AC.
These sound great! Which sensors and controls do you get in HA? I would like to be able to trigger the alarm in automations.
Second this question since I’m also looking to buy. It would be nice to know what entities Wiser devices provide for Home Assistant.
If you’re using Zigbee2MQTT you can check the device page on zigbee2mqtt.io
eg: Schneider Electric W599501
lists: Smoke (binary), Battery low (binary), Tamper (binary), Battery (numeric), Voltage (numeric), Temperature (numeric), Linkquality (numeric)
