ive configured the mqtt cloud service to integrate with HA and localize my device.
The device send the position to mqtt cloud withoup problem burt when add the configuration in configuration.yaml i’m unable to reload HA
The configuration need 2 block
The first is this:
mqtt:
broker: nome_server #tipo m20.cloudmqtt.com
port: 24322
username: !secret mqtt_username
password: !secret mqtt_password
If check the configuration from HA is ok and if reload the HA all works.
The second problemartic block is this
device_tracker:
-platform: owntracks
max_gps_accuracy: 100
If i check the confi it’s ok but when reload the log still in pending and HA not run
Any Idea?
