Where are dashboard resources tab in the new UI?
on HA core 5.2
from config → dashboards
you will see a page with 2 tabs, one is dashboards and the other is resources.
Resources page shows a list of javascript modules for customized lovelace cards.
Now, in the new UI meeting, it is setting → dashboards.
there is no resources tab any more.
where do I add javascript modules?
user profile advanced is true.
In the new layout that tab is missing yes. For some reason its hidden under the 3 dots in the upper right.
Just FYI, the HA OS version has no bearing on what you see in the front end. Only the core version (e.g. 2022.6.7) matters for this.
Illustrating what Charles said:
@tom_l @Hellis81
Your guys are amazing. It is so fast. Thanks so much.
Hi everyone
I don’t have the 3 dots in HA 2022.9.6
Has it been moved again ? It’s not showing up on my instance nor on a new one, and not showing up on 2 different browsers either
Any clue ?
Edit : Adding resources to lovelace - #8 by ludeeus it should be easy to find in the docs but I had to google the exact correct words in order to find this information.
The documentation for this located here is incorrect.
I don’t see any inaccuracies on that page. What is wrong with it?
I should probably turn on email notifications so I see these messages, I believe the inaccuracy has been addressed. I think it was around Advanced Mode needing to be enabled.
