Hi guys,
I used schedy a long time but want to change to a simpler overview about my heaters.
which integration is simple and will fit for:
- 3x heaters with Fritz dect 301 (bath, sleeping room and office)
- sometimes I have to change the plan for office due to homeoffice
- time plan for weekdays and weekend
- no window detection necessary
- maybe it is possible to use the aqara temp sensors from each room instead of the temp sensor from the Fritz parts?
rest of my apartment is with heated floor and not smart.
Do you have some ideas which integration fits to my requirements?
Regards
Timo
Edit:
I found 🔥 Advanced Heating Control this blueprint and start the configuration.
This is exactly what I wanted
I’m also using the Blueprint and the Fritz DECT 301. How did you manage to get the Blueprint to override the FritzBox configuration?
The 301s always use the temperatures set in the FritzBox by default, not the ones I configured in the Blueprint.
Thanks for your response!
I dont have any settings done in the fritzbox app
therefore there are no data to override.
Did you try it?
              How did you integrate the thermostats into Home Assistant? Directly? I thought it always had to be done via the Fritz!Box.
              yes, but I deleted the time plan from fritz in the app.
              Does the FritzBox stop sending commands to Home Assistant or the thermostats in this case? I’ve also disabled the schedule, yet the FritzBox is still interfering with my blueprints and automations, breaking them.
