Which data shoud i use to send ir code
i am trying to turn on mi tv , the ir code i have recived from arduino uno is
which data should i use to send ir code through ir transmiterr in esphome
previous code
Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x356 10 bits LSB first
Raw result in internal ticks (50 us) - with leading gap
rawData[24]:
     -65535
     +  23,-  11     +  12,-  12     +  14,-  28     +  13,-  29
     +  13,-  12     +  14,-  28     +  14,-  11     +  15,-  27
     +  12,-  13     +  12,-  30     +  12,-  30     +  13
Raw result in microseconds - with leading gap
rawData[24]:
     -3276750
     +1150,- 550     + 600,- 600     + 700,-1400     + 650,-1450
     + 650,- 600     + 700,-1400     + 700,- 550     + 750,-1350
     + 600,- 650     + 600,-1500     + 600,-1500     + 650
Result as internal ticks (50 us) array - compensated with MARK_EXCESS_MICROS=20
uint8_t rawTicks[23] = {23,11, 12,12, 14,28, 13,29, 13,12, 14,28, 14,11, 15,27, 12,13, 12,30, 12,30, 13};  // Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x356 10 bits LSB first
Result as microseconds array - compensated with MARK_EXCESS_MICROS=20
uint16_t rawData[23] = {1130,570, 580,620, 680,1420, 630,1470, 630,620, 680,1420, 680,570, 730,1370, 580,670, 580,1520, 580,1520, 630};  // Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x356 10 bits LSB first
uint16_t address = 0x0;
uint16_t command = 0x0;
uint32_t data = 0x356;
Pronto Hex as string
char ProntoData[] = "0000 006D 000C 0000 002D 0014 0018 0016 001C 0035 001A 0037 001A 0016 001C 0035 001C 0014 001E 0033 0018 0018 0018 0039 0018 0039 001A 06C3 "
Space between two detected transmission is greater than 5000 but smaller than the minimal gap of 20000 known for a protocol.
Try to increase the RECORD_GAP_MICROS in IRremote.h.
rawData[24]:
     -212
     +  23,-  10     +  14,-  10     +  14,-  28     +  13,-  29
     +  15,-  10     +  14,-  28     +  14,-  10     +  15,-  27
     +  14,-  11     +  14,-  28     +  14,-  28     +  14
rawData[24]:
     -10600
     +1150,- 500     + 700,- 500     + 700,-1400     + 650,-1450
     + 750,- 500     + 700,-1400     + 700,- 500     + 750,-1350
     + 700,- 550     + 700,-1400     + 700,-1400     + 700
uint8_t rawTicks[23] = {23,10, 14,10, 14,28, 13,29, 15,10, 14,28, 14,10, 15,27, 14,11, 14,28, 14,28, 14};  // Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x356 10 bits LSB first
uint16_t rawData[23] = {1130,520, 680,520, 680,1420, 630,1470, 730,520, 680,1420, 680,520, 730,1370, 680,570, 680,1420, 680,1420, 680};  // Protocol=PULSE_DISTANCE Address=0x0 Command=0x0 Raw-Data=0x356 10 bits LSB first
char ProntoData[] = "0000 006D 000C 0000 002D 0012 001C 0012 001C 0035 001A 0037 001E 0012 001C 0035 001C 0012 001E 0033 001C 0014 001C 0035 001C 0035 001C 06C3 "
