Which is it, dashboard will no longer be automatically updated or will it be?
I would love to make some custom dashboards for different uses, but I don’t want to loose the one automatically maintained by the system.
Blog entry 0.107: Multiple Lovelace Dashboards, adds helpers, new media player card back on Mar 18 said:
You can have a dashboard with your main layout, one that is auto-generated (like the old State UI), one for experimenting, one for admins, one for your wall-mounted tablet, etc.
But when you select “Configure UI” I get a warning:
This dashboard is currently being maintained by Home Assistant. It is automatically updated when new entities or Lovelace UI components become available. If you take control, this dashboard will no longer be automatically updated. You can always create a new dashboard in configuration to play around with.
Are you sure you want to take control of your user interface?
So I always opt out.
Which is true?
Will I loose the automatically updated dashboard or will I still have one?
Thanks,
-Mike
Go into Configuration > Lovelace Dashboards, create a new one and indeed, you take control of that specific one. The “default” will still be automatically populated
Thank you!!!
I’ve looked for some way to do that and never found it.
-Mike
Put this in your config.yaml file:
lovelace:
  mode: storage
  dashboards:
    test1-doug:
      mode: yaml
      title: BBQ THERMOMETERS
      show_in_sidebar: true
      filename: test1.yaml
you can add another dashboard…test2.doug if you want more than one. The base dashboard will be left alone and automatically populate with new items.
create a new file test1.yaml and any other dashboards you create in the config folder…and edit them there. The original will still be available at Overview. when you click on the new page in the sidebar, look at the URL of the page…that’s how you show your new page.
To see all the desktops, go to configuration/lovelace dashboards.
Note…you can’t get to your new page from the overview dashboard…you have to address it correctly. in my case http://192.168.254.201:8123/test1-doug
Note: You are correct, the documentation on how to do this is very confusing…
