George F. Will once said: “The future has a way of arriving unannounced.”
Well, George, we don’t agree: Announcing the release of Home Assistant Core 0.107!
This release brings a crazy amount of awesome new features and beautiful improvements to the frontend.
Bye old State UI
As announced with 0.105, the old States UI is now removed from Home Assistant. If you are using Home Assistant for a year or less, you might not have an idea what it is, since the “new” Lovelace UI has been the default. It is the UI we used before Lovelace.
If you are up for a flashback, maybe it is worth reading the release notes for Home Assistant 0.7 were the revamped (and now removed) States UI was originally announced. Now exactly 100 releases later, it is time to say goodbye to the states UI that has been with us for a long, long time…
As we announced the deprecation of the old States UI in 0.105, not everybody seemed to be that happy about it. So we surveyed to see what one would miss from States UI and learned that it is mostly used as an overview of all entities (besides having a nice layout that can be made in Lovelace).
In this release, we bring you a Lovelace solution for that and added a bit more…
Hello multiple Lovelace dashboards
You are now able to create multiple Lovelace configurations, called: Lovelace Dashboards!
You can have a dashboard with your main layout, one that is auto-generated (like the old State UI), one for experimenting, one for admins, one for your wall-mounted tablet, etc.
And, yes, you can even mix and match multiple YAML mode managed Lovelace Dashboard, UI managed Lovelace Dashboards and auto-generated Lovelace Dashboards at the same time.
 Screenshot of the new Lovelace configuration panel.
Each dashboard can be added to the menu sidebar as well, with a configurable title and icon. Furthermore, it is possible to limit access to a dashboard to admin users only.
An unlimited amount of dashboards can be created right from the UI in the new
Lovelace configuration panel, and YAML dashboards can be set up in
configuration.yaml, see the documentation.
This awesome new feature comes with a deprecation if you use Lovelace in
manual YAML mode: You need to move the resource section from
your ui-lovelace.yaml to the lovelace: section in configuration.yaml.
It is not a breaking change yet; we still load them from the previous location
if we didn’t find anything in the lovelace: section, however, this fallback
is being removed in a future version.
If you manage your Lovelace via the frontend, we automatically migrate your resources. Please note that resources are not in the raw Lovelace configuration editor anymore, but in the Lovelace configuration panel.
New media player card
@zsarnett is back on the frontend team and is not planning on letting that happen unnoticed. He did a ton of work on the frontend and created a beautiful new media control card for Lovelace.
It is inspired by the media control widget in Android and changes color based on the artwork of the played media. We think it looks absolutely gorgeous!
 Screenshot of the new Media Control Card.
Helpers Configuration Panel
When you create advanced automations, you often need a helper. Like a toggle,
to save a state, or another input field. Until now, you always had to define
them in YAML and are known as the input_* fields/integrations.
We now have a UI to add and manage these Helper elements; this allows non-expert users, or anybody that prefers the frontend to manage their system, to also access this functionality.
 Screenshot of a helper configuration dialog.
Thanks @Adminiuga, for implementing the backend features that made this
frontend change possible! Not only that, if you prefer YAML, these changes
made by @Adminiuga also made it possible to reload the input_* YAML
configuration without restarting Home Assistant.
Improvements to Lovelace editing experience
@zsarnett changed the looks of our card picker, instead of a simple button to pick a card, you now get a live preview with your own entities. @thomasloven added a UI editor for the horizontal and vertical stack cards and the conditional card.
Screen recording of the new card picker and stack editor.
Other noteworthy changes
- @Misiu added a UI to set the visibility per user for views.
- Data tables, for example, the Entities configuration panel, are now lightning fast! Even on mobile 🚀.
- The logbook had some speed improvements, thanks @KapJI!
- @bdraco just went all-in on the August integration, making it a top-notch integration! Awesome job there!
- Initial support for HomeKit enabled televisions and support for occupancy sensors was added by @Jc2k.
- @tulindo added support for newer SamsungTV models.
- Alexa now supports starting and cancelling timers, thanks to @Tho85.
New Integrations
New Platforms
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat.
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
Xfinity Gateway (Deprecated) - The Xfinity Gateway integration relies on web scraping and is deprecated, to be removed in Home Assistant Core 0.109. (ADR-0004) - (@frenck - #32017)
Groups - Groups are NOT being removed, but the configuration options, services, and service options related to the (previously deprecated and now removed) States UI are now removed in this release. This includes:
- The
viewandcontrolconfiguration options for a group. - The
group.set_visibilityservice call - The
control,visible,viewoptions on thegroup.setservice call
Please ensure your configuration and automations do not use these anymore. - (@frenck - #32021) (group docs)
- The
Input Number - Adds an entity ID to input_number warning. Passing an out of range value to
input_number.set_valuewill now raise a validation error. Incrementing/decrementing aninput_numberwill no longer cause warnings. - (@balloob - #32012) (input_number docs) -
History Graph - The
history_graphintegration has been deprecated in Home Assistant 0.105 and is now removed. This integration was used for the old states UI, which is no longer available. A Lovelace an equivalent is available: The Lovelace History Graph. (@frenck - #32028) -
Weblink - The
weblinkintegration is was deprecated in 0.105.0 and now removed. This integration only works with the old states UI, which is no longer available. (@frenck - #32024)With Lovelace, the same can be achieved using:
Environment Canada - This integration was previously using web scraping for weather alert details. The details attribute has been removed to make it compliant. (ADR-0004) - (@michaeldavie - #32077) (environment_canada docs)
Units of Time - Time units have been standardized throughout all integrations. - (@springstan - #32065)
If you were using a non standard unit in an automation or sensor please change it to the following:
- μs for microseconds
- ms for milliseconds
- s for seconds
- min for minutes
- h for hours
- d for days
- w for weeks
- m for months
- y for years
HomematicIP Cloud - Migrates HomematicIP Cloud services to admin services. - (@SukramJ - #32107) (homematicip_cloud docs)
The user needs to be in the administrator role to execute these HomematicIP Cloud services:
homematicip_cloud.dump_hap_confighomematicip_cloud.reset_energy_counter
HomeKit Controller - Support for HomeKit controller’s legacy pairing data folder
.homekithas been deprecated and in Home Assistant Core release 0.109.0 we plan to remove this code. Pairings have not been saved this way since Home Assistant 0.94, so if you are running Home Assistant 0.94 or later this does not affect you - your pairings were already migrated to configuration entries. If you are running an older release and do not upgrade soon you will not be able to automatically migrate your existing pairings at upgrade time and will have to manually re-pair them. - (@Jc2k - #32158) (homekit_controller docs) -
Automation - The
hide_entityconfiguration option on an automation was deprecated in Home Assistant 0.105 and is removed in this release. It was used for the old states UI, which is no longer available, making this option obsolete. Please ensure your configuration is not using this option. - (@frenck - #32038) (automation docs) -
IQVIA - When configuring IQVIA via
configuration.yaml, themonitored_conditionskey has been deprecated and will be removed in 0.114.0. All sensors are now created by default. (ADR-0003) - (@bachya - #32223) (iqvia docs)Example YAML configuration:
iqvia: zip_code: !secret iqvia_zip_code -
GitHub - The entity state has been changed to return the ‘short SHA’ commit hash, so automations based on
latest_commit_shashould be adapted to that. - (@Mariusthvdb - #31581) (github docs) -
AirVisual - AirVisual is now available to be added through the integrations UI! If you configure it in
configuration.yamlyou will need to update to the new configuration. Additionally, in order to protect the AirVisual cloud API,scan_intervalin no longer configurable for this integration. - (@bachya - #32072) (airvisual docs)Example YAML configuration:
airvisual: api_key: !secret airvisual_api_key -
IFTTT - IFTTT now checks that received webhook data is a dictionary (example
{ "value": 1 }) to prevent Home Assistant internals from breaking. - (@balloob - #32317) (ifttt docs) -
AlarmDecoder - AlarmDecoder integration now uses Honeywell’s Instant mode instead of Night-Stay for
alarm_arm_night. Instant mode is generally thought to be more secure for night-time use because it disables the entry delay since visitors aren’t expected. - (@ajschmidt8 - #32292) (alarmdecoder docs) -
Tibber - Upgraded Tibber library to 0.13.0 and some attributes have names which have changed. - (@Danielhiversen - #32369) (tibber docs)
currentPhase1->currentL1 -
currentPhase2->currentL2 -
currentPhase3->currentL3
REST - Add
application/xmlas an XML to JSON auto converted MIME types for rest sensors - (@bdraco - #32289) (rest docs) -
Certificate Expiry - The
nameconfiguration option has been deprecated and is no longer used by the integration. An improved default entity & display naming scheme is provided. Name and entity_id overrides should be handled via the frontend. Configurations using name will marked broken with the 0.109 release. - (@jjlawren - #32066) (cert_expiry docs)Example YAML configuration:
sensor: - platform: cert_expiry host: google.com -
Plex Media Player - The ‘show all controls’ option for Plex is deprecated and will be removed in the Home Assistant Core 0.110.0 release. Also, discovery and legacy config file loading (plex.conf) has been removed. - (@jjlawren - #32391 #32510) (discovery docs) (plex docs)
plex: media_player: show_all_controls: True <-- Deprecated -
Abode - Abode retired its legacy automations and quick actions on 28 Feb. This change removes support for legacy automations and quick actions while adding support for CUE automations which will show up in Home Assistant as switches (same as previous implementation). Abode’s replacement for quick actions is manually triggered CUE automations which can be called through Home Assistant service
abode.trigger_automation(previously labeledabode.trigger_quick_action). - (@shred86 - #32296) (abode docs) -
deCONZ - The events on the Aqara Magic Cube have changed, so they will match with the device triggers discriptions. If you made automations for the Magic Cube on the device page, you will want to change your automation. If you configured your automations based on events from the developers tools, there is nothing breaking. This also fixes the double tap function on side 2, which didnt work if you configured it in the device page - (@Dorzel107 - #32108) (deconz docs)
Emoncms - The way the
unit_of_measurementis set has changed to make use of the ability for this to be set in the source feed in Emocms. - (@borpin - #32042) (emoncms docs)The unit will now be assigned as follows:
- Take the unit from the API if it is available
- Otherwise take the unit from config, either specified or the default unit (W)
Vizio SmartCast TV - Adds app support. For TVs that support apps, ‘SMARTCAST’ and ‘CAST’ sources have been replaced with
SmartCast Home. Any automations that rely on those sources will need to be updated. - (@raman325 - #32432) -
Onvif - Added more onvif PTZ move modes. The onvif camera service
camera.onvif_ptzhas been moved from the camera domain to the onvif domain.onvif_ptzservice was also renamed toptz, so service calls need to be updated toonvif.ptz. - (@olijouve - #30152) (onvif docs)Example YAML configuration:
- type: entity-button entity: camera.foscam icon: mdi:arrow-left-bold-outline show_name: false tap_action: action: call-service service: onvif.ptz service_data: entity_id: camera.foscam pan: LEFT tilt: zoom: move_mode: ContinuousMove continuous_duration: 0.8 distance: 1 -
Facebook Messenger - On October 29, 2019 Facebook announced a breaking change that all broadcast API will stop working on March 4th, 2020, so BROADCAST as a target option is now removed. - (@chmielowiec - #32517) (facebook docs)
Samsung Smart TV - Adds support for newer SamsungTV models. Specifying the port in
configuration.yamlis no longer needed and thus the port config option has been deprecated. - (@tulindo - #31537) (samsungtv docs) -
Netatmo - The unreliable binary sensors are removed since they don’t provide much value due to their polling nature. To trigger automations it is recommended to use the event netatmo_event. - (@cgtobi - #32673) (netatmo docs)
Example trigger for automations:
trigger: - event_data: type: movement event_type: netatmo_event platform: event -
DirecTV - DirecTV is now available to be added from the integrations UI. The concept of device has been removed and now the DirecTV receiver, and all client devices, are added. There is no longer a
portoption as the default port should work just fine. The name can be set via entity UI rather thannameoption. - (@ctalkington - #32162) (directv docs) (directv docs) -
iCloud - iCloud family devices are no longer added automatically. Use the
with_familyconfiguration option or re-add the integration via the frontend, in case you do want to make use of the iCloud family devices. - (@Quentame - #32644) (icloud docs) -
Device Tracker - The
hide_if_awayconfiguration parameter has been removed for all device trackers. This option was used to hide devices trackers from the UI if the device was not at home. This applied to the old States UI, which now has been removed. - (@frenck - #32705) (device_tracker docs) (breaking change) (beta fix) -
Sonos - Sonos devices will now report
idleinstead ofpausedif they do not have any current artist metadata available. This can happen when you were playing Spotify on your Sonos and use the Spotify app to play on another device. - (@balloob - #32712) (sonos docs) (breaking change) (beta fix)
Beta Fixes
All changes
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2020/03/18/release-107/
since upgrade to 107.0
