Which system
Hi everyone!
I’ve installed hassio and setup the ssh and I would like to install gitlab next to home assistant. Unfortunately I don’t know on which system Hassio is based. So I can’t run several commands. Someone knows if it’s possible ?
Thanks a lot
Rémi
Hassio uses add-ons to install software.
Check out my repo where I created an add-on for Gogs, which is a light weight alternative to Gitlab.
Gogs is definitely the way to go!
Thank you it works perfectly!
