Why can’t there be both tag’s/labels plus folders in the GUI for entities like Script’s & Automations?
If an object or entity (script/Automation) had A label/tag option, that excepts “/“ that represent sub tags or Folders in the GUI & “,” as separate Tags. E.g.
  1. Tag: “Lights” shows in the GUI in the Folder “Lights”.
  2. Tag: “Light/Effects” would show in the GUI in the Folder “Effects”, nestled under the Folder “Light”.
  3. Tag: “Lights, Effects” would show in the GUI in both folders “Effects”, & the Folder “Lights”.
  4. Tag: “Light/Effects, Light” would show in the GUI in both folders “Light”, & the Folder “Effects”, nestled under the Folder “Light”.
  5. Tag: ““is empty”” or “root” would show up under the root folder in the GUI.
alias: A Light Script
tags: light, light/effects
sequence:
  - service: light.turn_on
    data: {}
      area_id: office
mode: single
And the “Tag” option can be reference via HAss Jinja2 extension’s
state_attr ( script.a_light_script, 'tags')
When moving entities in the GUI to a different folder, the GUI gives the options “Change” &or “Both”.
Reference# Labels, Tags & Folders for Automation Scripts
Closing as a duplicate of:
