Why did these SONOFF ZBminis not work?
Simple 1 switch 1 light set up.
I’ve got slightly unusual (for a 25 year old house in the UK) 3 wire system with neutral at the switch - bonus! However when I wired up this SONOFF ZBMini module, I can’t get it to work reliably. ZHA pairing finds it almost instantly. Everything works OK initially but about 2-5 minutes after pairing I get the following events, and the module becomes unusable until I re-pair it, and then it stops working again after a few minutes.
  • SONOFF 01MINIZB Identify became unknown
  • SONOFF 01MINIZB Firmware turned off
  • SONOFF 01MINIZB Identify became unavailable
  • SONOFF 01MINIZB Light became unavailable
  • SONOFF 01MINIZB Firmware became unavailable
Tried with two different modules.
Is it likely to be:
  1. Wired incorrectly
  2. Zigbee network issue
  3. Broken modules (have tried two)
  4. Something else?
Noddy wiring diagram:
All help and advice gratefully appreciated as I really want to be able to use these throughout my house!
Hi thebunk,
Well if you get it paired, then stick it in the metal box in the wall, and it looses it, you have a weak mesh network and need more routing nodes closer to the switch(s).
Here are a few posts about helping your mesh zigbee network with devices that fall off the mesh.
Appreciate that thank you. I should have said - this is while I’m testing it so all the guts are still hanging out of the wall rather than put back in the box.
Also should have said - this is in the same room as the zigbee gateway (Sonoff Zigbee Dongle-P)!
Is your zigbee mesh OK/stable otherwise?
TIP: check this Zigbee network optimization: a how-to guide for avoiding radio frequency interference…
Maybe you learn something new…
