I have HA setup in a Docker Container on a Raspberry Pi5. I have a few devices connected, one of which being my Risco Cloud alarm system.
I’m just learning at the moment, and understanding how to configure things, but I’m stuggling with manually editing devices, as there is nothing useful in my configuration.yaml, which every internet guide seems to point me towards.
I have a Docker volume mapped to the /config folder in the HA image. I can see the automations.yaml includes all of the automations I have configured, but this is all that shows in configuration.yaml:
You have default _config in your configuration.yaml. This includes a lot of integrations for you. All these listed here: Default Config - Home Assistant
configuration.yaml is never written to by HA, only read from. “Every internet guide” tends to be out of date: HA is moving more and more towards full UI configuration. Automations, script and scenes are a bit of an outlier in that regard: most “incoming” config is stored in registries and files that you should not be fiddling with.
If your devices are already in HA, there’s rarely any YAML editing needed or possible.
Which devices are you trying to “manually edit” and why?
Also understand the difference between devices and entities. HA mostly runs off entities (such as a binary sensor as to whether your alarm has triggered; or a backup battery voltage sensor), which can be associated with devices.
Didn’t spot the </> option, as it was hidden under the cog button.
Thanks, understood about the configuration.yaml. So out of interest, where in the system does it store device information and settings?
Specifically, I was wondering if it was possible to edit a device to ignore specific states. With Risco Cloud, whenever their API is down, I get a “became unavailable” state, which then when it returns triggers one of my automations.
I tried using a “template” to ignore changes from “unavailable”, but that hasn’t worked, but I could have done it wrong. I’m learning!
So I suppose, the question is - can I change devices to only listen/record specific events, so I could ignore the “unavailable” one that is causing automation issues?
Then the second question is, what did I do wrong with my automation?
States of discovered and UI created devices are not user editable. And you dont need to anyway. You just need to adjust your trigger.
- platform: state
entity_id: 49f4065f83bc6ee64822716db015bd2e # change this to the actual entity id
to: 'armed_away'
not_from:
- unknown
- unavailable
Brilliant, thank you! That’s great advice, I’ll have a read and give that a try!
Another question, not related to scripting…
How do you backup and restore configuration?
I have the config folder backed up, but if none of the devices configs are stored in there, copying this back into a fresh instance wouldn’t reinstate my current devices surely?
