I have configurations for knx in a separate folder and depending on the file name the hardware type is determined.
I have
knx: !include_dir_named knx/
in configuration.yaml
and folder knx with yaml files
Everything works except what is in fan.yaml, in HA the fans are displayed with correct icons but nothing happens when turning on, if you move the config from fan.yaml for example to light.yaml everything works, but the fans have wrong icons.
if I add
knx:
fan:
- name: "Ceiling fan"
address: "9/0/1"
state_address: "9/0/2"
with my data in configuration.yaml fan still dont work
it some problem with fan for home assistant?
for example
knx:
light:
address: "9/0/1"
works fine!
