Hello everyone!
To be honest I am a bit confused.
I am planning to buy a smart thermostat or control the current one by placing a Shelly on it.
I would prefer to have a smart one mainly due to visual result.
So I found this one Floureon HY08WE
Is it going to work with the uspass/hysenheating in 0.99?
And a bonus question. What about adding it in HACS?
Hi, i use this thermostat:
with this component:
in Hassio 0.99.2 on Rpi 3b+ and all is working.
Giovani the component is working fine to 0.99.2 but if you install broadlink ir component then it stops. do have a solution?
I’m sorry but i don’t have other broadlink components…
Hedgehog57 , you solved?
I have modified custom component for Tuya-based thermostats. It works locally without thermostat modification. The code i’ve posted here:
after many attempts everything works. thanks Hedgehog57
is there anyone who have install the component with any other broadlink component together?? i can’t make this to work with smartir component.Any solution please?? everything was working before upgrade from 0.92.2. and now i can’t restore. I was having the floureon thermostat to control my heating and broadlink ir rm3 mini to control my A/c units. But with 0.99.3 these two can’t work together.
I can’t get the automation to work to turn on the heating - I used to use set operation mode - but thats no longer a climate service - only HVAC
- id: EnSuite underfloor heating on
alias: EnSuite underfloor heating on
- at: 06:30:00
platform: time
- condition: and
conditions:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- below: 5
condition: numeric_state
entity_id: sensor.dark_sky_outside
- data:
entity_id:
- climate.underfloorheating
temperature: 25
service: climate.set_temperature
- data:
entity_id:
service: climate.turn_on
- data:
entity_id:
hvac_mode: heat
service: climate.set_hvac_mode
- id: EnSuite underfloor heating off
alias: EnSuite underfloor heating off
- at: 07:00:00
platform: time
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- data:
entity_id:
temperature: 15
- data:
entity_id:
service: climate.turn_off
- data:
entity_id:
hvac_mode: off
Can anyone share how they set the mode?
@Robbrad, this is my automation to switch on my heating using a switch on the frontend and a slider to set a time after that the heating automatically switch off.
# *********************************** Automazione avvio temporizzato caldaia ***********************************
- alias: 'caldaia temporizzata on'
- platform: state
entity_id: input_boolean.switch_caldaia_timer
to: 'on'
entity_id: climate.termostato
temperature: 19.5
- alias: 'caldaia temporizzata off'
- platform: state
to: 'off'
- platform: state
to: 'on'
for:
minutes: '{{ states.input_number.caldaia_timer.state | int }}'
- service: climate.set_temperature
temperature: 15
- service: climate.set_hvac_mode
hvac_mode: auto
Thanks however I think there is an issue in the componenent can you help @cooljimy84 ?
Automation:
entity_id: climate.underfloorheating
temperature: 25
- service: climate.turn_on
hvac_mode: 'auto'
2019-10-05 07:09:17 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.ensuite_u
nderfloor_heating_on. Unknown error for call_service at pos 2:
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/components/automation/__init__.py", line 434, in action
await script_obj.async_run(variables, context)
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 162, in async_run
await self._handle_action(action, variables, context)
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 246, in _handle_action
await self._actions[_determine_action(action)](action, variables, context)
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 329, in _async_call_service
context=context,
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 98, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1234, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1259, in _execute_service
await handler.func(service_call)
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 213, in handle_service
self._platforms.values(), func, call, service_name, required_features
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 349, in entity_service_call
future.result() # pop exception if have
File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 371, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/home/rob/.homeassistant/custom_components/floureon/climate.py", line 386, in async_turn_on
if self._last_on_operation is not None:
AttributeError: 'BroadlinkPIDThermostat' object has no attribute '_last_on_operation'
It seems to be complaining about the PID.
I use nodered to call my heating. Are you able to call each one separately and see which one produces the error?
Im pretty sure its the HVAC - as the temp get set correctly
Though it could be the off. Let me try
ok I was wrong not the hvac.
I remove the set HVAC - just to set temp and turn on
Temp gets set correctly so it must be the turn on
2019-10-05 08:37:17 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=climate, service=turn_on,
service_data=entity_id=['climate.underfloorheating']>
2019-10-05 08:37:17 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.ensuite_u
You don’t have to use climate.turn_on. Just set the temperature and it will switch on in manual mode.
Thanks @gt4020
Got it working final code - in the end I needed the off but not the on
- at: 06:30:00
platform: time
- condition: and
conditions:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- below: 5
temperature: 25
hvac_mode: auto
- at: 07:00:00
platform: time
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
temperature: 15
- service: climate.turn_off
hvac_mode: off
Please update component from hass-components/floureon at 71f6705f5a873b6f228fdb895da7fe0e671a6142 · algirdasc/hass-components · GitHub
Hi. I am looking to buy a wifi thermostat (water heat) that integrates with home assistant (220V)
I have found the following 2.
Can you tell me if I ir is ok to order them or suggest me another one who is actually works with HA?
Hi all
Can you please let me know which component I have to use to connect my Thermostat to HA?
I bought mine together with floor heating mats a while ago, and I can connect my thermostat to my phone using Beca app. Please see below the image of mine thermostat
So far, I did try to use floureon component and hysenheating, and unfortunately, I was not able to connect. Please, can you advise?
I bought the Beok BOT-313 thermostat. Please someone describe the first steps in order to integrate it to HA. Where from I can download the broadlink folder to apply it in custom_componets file?
