Wifi thermostat (Beok, Floureon, Beca Energy) component
I’m sorry but i don’t have other broadlink components…
Hedgehog57 , you solved?
I have modified custom component for Tuya-based thermostats. It works locally without thermostat modification. The code i’ve posted here:
after many attempts everything works. thanks Hedgehog57 :wink:
is there anyone who have install the component with any other broadlink component together?? i can’t make this to work with smartir component.Any solution please?? everything was working before upgrade from 0.92.2. and now i can’t restore. I was having the floureon thermostat to control my heating and broadlink ir rm3 mini to control my A/c units. But with 0.99.3 these two can’t work together.
I can’t get the automation to work to turn on the heating - I used to use set operation mode - but thats no longer a climate service - only HVAC
- id: EnSuite underfloor heating on
  alias: EnSuite underfloor heating on
  - at: 06:30:00
    platform: time
  condition:
  - condition: and
    conditions:
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
    - below: 5
      condition: numeric_state
      entity_id: sensor.dark_sky_outside
  - data:
      entity_id:
      - climate.underfloorheating
      temperature: 25
    service: climate.set_temperature
  - data:
      entity_id:
    service: climate.turn_on
  - data:
      entity_id:
      hvac_mode: heat
    service: climate.set_hvac_mode
- id: EnSuite underfloor heating off
  alias: EnSuite underfloor heating off
  - at: 07:00:00
    platform: time
  condition:
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
    - sat
    - sun
  - data:
      entity_id:
      temperature: 15
  - data:
      entity_id:
    service: climate.turn_off
  - data:
      entity_id:
      hvac_mode: off
Can anyone share how they set the mode?
@Robbrad, this is my automation to switch on my heating using a switch on the frontend and a slider to set a time after that the heating automatically switch off.
# *********************************** Automazione avvio temporizzato caldaia ***********************************
  - alias: 'caldaia temporizzata on'
      - platform: state
        entity_id: input_boolean.switch_caldaia_timer
        to: 'on'
      entity_id: climate.termostato
        temperature: 19.5
  - alias: 'caldaia temporizzata off'
      - platform: state
        to: 'off'
      - platform: state
        to: 'on'
        for:
          minutes: '{{ states.input_number.caldaia_timer.state | int }}'
      - service: climate.set_temperature
          temperature: 15
      - service: climate.set_hvac_mode
          hvac_mode: auto
      - service: input_boolean.turn_off
Thanks however I think there is an issue in the componenent can you help @cooljimy84 ?
Automation:
      entity_id: climate.underfloorheating
        temperature: 25
    - service: climate.turn_on
        hvac_mode: 'auto'
2019-10-05 07:09:17 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.ensuite_u
nderfloor_heating_on. Unknown error for call_service at pos 2:
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/components/automation/__init__.py", line 434, in action
    await script_obj.async_run(variables, context)
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 162, in async_run
    await self._handle_action(action, variables, context)
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 246, in _handle_action
    await self._actions[_determine_action(action)](action, variables, context)
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/script.py", line 329, in _async_call_service
    context=context,
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 98, in async_call_from_config
    domain, service_name, service_data, blocking=blocking, context=context
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1234, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1259, in _execute_service
    await handler.func(service_call)
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 213, in handle_service
    self._platforms.values(), func, call, service_name, required_features
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 349, in entity_service_call
    future.result()  # pop exception if have
  File "/home/rob/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 371, in _handle_service_platform_call
    await getattr(entity, func)(**data)
  File "/home/rob/.homeassistant/custom_components/floureon/climate.py", line 386, in async_turn_on
    if self._last_on_operation is not None:
AttributeError: 'BroadlinkPIDThermostat' object has no attribute '_last_on_operation'
It seems to be complaining about the PID.
I use nodered to call my heating. Are you able to call each one separately and see which one produces the error?
Im pretty sure its the HVAC - as the temp get set correctly
Though it could be the off. Let me try
ok I was wrong not the hvac.
I remove the set HVAC - just to set temp and turn on
Temp gets set correctly so it must be the turn on
2019-10-05 08:37:17 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=climate, service=turn_on,
service_data=entity_id=['climate.underfloorheating']>
2019-10-05 08:37:17 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.ensuite_u
You don’t have to use climate.turn_on. Just set the temperature and it will switch on in manual mode.
Thanks @gt4020
Got it working final code - in the end I needed the off but not the on
  - at: 06:30:00
    platform: time
  condition:
  - condition: and
    conditions:
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
    - below: 5
        temperature: 25
        hvac_mode: auto
  - at: 07:00:00
    platform: time
  condition:
  - condition: time
    weekday:
    - mon
    - tue
    - wed
    - thu
    - fri
    - sat
    - sun
        temperature: 15
    - service: climate.turn_off
        hvac_mode: off
Please update component from hass-components/floureon at 71f6705f5a873b6f228fdb895da7fe0e671a6142 · algirdasc/hass-components · GitHub
Hi. I am looking to buy a wifi thermostat (water heat) that integrates with home assistant (220V)
I have found the following 2.
Can you tell me if I ir is ok to order them or suggest me another one who is actually works with HA?
1.https://www.amazon.co.uk/MOES-Thermostat-Temperature-Controller-Programmable,Works/dp/B07Q9QMFM6/ref=sr_1_8?keywords=wifi+water+heating+thermostat&qid=1570364551&sr=8-8
2.https://www.amazon.co.uk/Thermostat-Programmable-Temperature-Controller-Smartphone/dp/B076BNCYPN/ref=sr_1_7?crid=2KTUQBKQ7KWW&keywords=wifi+thermostat&qid=1570364172&sprefix=wifi+the%2Caps%2C223&sr=8-7
Hi all
Can you please let me know which component I have to use to connect my Thermostat to HA?
I bought mine together with floor heating mats a while ago, and I can connect my thermostat to my phone using Beca app. Please see below the image of mine thermostat
So far, I did try to use floureon component and hysenheating, and unfortunately, I was not able to connect. Please, can you advise?
I bought the Beok BOT-313 thermostat. Please someone describe the first steps in order to integrate it to HA. Where from I can download the broadlink folder to apply it in custom_componets file?
I have bought the number 1 and it works quite well. For now all is well with floureon
Hi i have a beok 313.
I set the pid and it works, the thermostate show in my config and i seem able to control it manually but i don’t get temperature reading: i always get 0 in the thermostat circle in home assistant and i had to reset the sensor itself phisically on the thermostat cause it was showing error, any hints?
i have this error:
Invalid config for [climate.floureon]: [use_extrenal_temp] is an invalid option for [climate.floureon]. Check: climate.floureon->use_extrenal_temp. (See ?, line ?). Please check the docs at https://home-assistant.io/integrations/climate.floureon/
My config:
climate:
  • platform: floureon
    host: 192.168.1.2xx
    mac: 78:0F:77:FA:AD:xx
    use_extrenal_temp: false
I had the similar problem. There is a spelling error in the example config.
The last line should be: use_external_temp: false
