Windows says 8123 is denying access
Maybe your virtual network is configured wrong.
I would agree with you except it failed without any changes. Virtual does appear correct. Just tried taking my switch out of line to see if that was itā€¦no changes. 4357 is good and 8123 is not.
try to update your core in the VM console
ā€œcore updateā€ ā€¦ and restart
ā€œcore restartā€
and as you have a new HA installation you should only use HTTP, if you get back the same error above in browser canā€™t access HTTPS, it seems itā€™s your browser try another browser any/all , device on pc/laptop (not your phone, not through Teamviewer)
struck out on all. Did update and restart without resolution. Currently building a new PC to see if its router problem.
Ok, thou i donā€™t understand what you mean by the last sentences, on the other hand, im not familiar with your network setup/hardware
I thought by setting up a new PC I could isolate the problem to hardware. Just so time consuming. Very frustrated as Iā€™ve been sitting at my desk with this for over 12 hours. and no progress.
ok, yes ā€œisolate by excludeā€ is sometimes needed, thou HA seems to work fine, and get itā€™s(correct) LAN settings(same as your other devices are on(mac, pc, laptop phone etc), from your ā€œRouterā€ i assume, unless you have some external DHCP, and by nslookup command in windows you verify from which device you get name-resolution (most likely also from your Router) , as i mentioned earlier, so al this still looks good ( thou ofcause you havenā€™t verified ā€œhereā€ whether this is right ).
I donā€™t know about Virtual-Box, as i use VMware Player, i find it more stable and easier
1 thing that can mess up things (depending upon the network), is that you have 2st IP-v6 in your HA instance(in same interface), i would disable them(never seen 2, and you most likely donā€™'t even need 1)
And check your Router, and make sure IPv6 is disabled there(best)
going to try and run this on VMPlayer and see if thatā€™s the issue.
well that didnā€™t work. It loaded HA but I cannot access anything thru .local:
OKā€¦DONE!!! I give upā€¦ $25.00 cup of coffee for anyone with the solution. DM me here.
An advice is to be more ā€œdetailedā€ initially in your OP, but also in the follow up
Like above, what didnā€™t work ?, installing on a new PC, Installing VMware, which version installed etc.
And ā€œverify/report backā€ if someone suggest an ā€œactionā€, so one can know on which ā€œpageā€ you are, what ā€œdetailedā€ actions you have performed etc.
ex. it took more than 1 day before you provided details from the VM monitor, as initally suggested by Wally, and later me 2 times ā€¦ And then it was on a newly installed HA , not the initial ā€¦ and your Header saying ā€œdenying accessā€ but the latest screenshot browser says ā€œcanā€™t connectā€ to https
So a good way of ā€œreportingā€ initially is always post screenshot of errors message, whether itā€™s from browser HA-front-end, or look up errors/respons in logfile , or through HA-Console(VM-monitor)
And when itā€™s access problems itā€™s also good to know when it started, how your network-setup looks like, i.e Router-setting(And i.e firewall setting in the Router), which DNS you use whether you have proxy etc. etc., the more relevant the better
You are trying to connect to httpS://192.168.1.35:8123 whereas your HA webUI is exposed on http://192.168.1.35:8123
Your points are well taken. As mentioned earlier Iā€™m a newbie and my nomenclature may not always be correct. If you can recommend a list of info to be posted, I will be glad to share any info I have. Iā€™m willing to follow the stepsā€¦just donā€™t know what they are. Thanks in advance Nick for any help going forward.
Iā€™ve tried http://, https:// and just the ip address with same resultā€¦
Most likely HA has a ā€œnewā€ IP now, but i believe he tried earlier(not that i know) as feedback lacks here
correctā€¦the new ip is 192.168.1.176. soā€¦http://192.168.1.176:4357 resolves perfectly BUT :8123 says the site cannot be reached.
Come on!
Do you have any local firewall setting in your router ? , which HA Core version ?
And as mentioned earlier, NABU CASA, i suggest you login to your NB account and disable the Service, as your HA most likely have change internal IP number more than the 3 time past 24 hours, and who knows maybe even your WAN IP ā€¦ which you can find in your Router-Settings
And you donā€™t have a ā€œWorkingā€ NABU CASA Service now, as you have reinstalled HA 3 Time, and not been able to install/activate it in HA
it says waiting for supervisor to startupā€¦ in a few of the screenshots in this thread
there was a supervisor update a couple of days ago, thats where i would be startingā€¦
Does this have the info youā€™re looking for?
