Let me take a quick look
Looks like some method calls were changed that shouldn’t have. Can someone give this a shot.
unzip the above file in side of YOUR_HA_CONFIG_DIR/custom_components/
and make sure the folder name is wink
That works for me in Hassio! Thanks!
Will upgrade, test and report back … thanks!!!
EDIT: This works, thank you so much!
On another note, I’m wondering why HA hasn’t considered supporting Sensi directly and not having to deal with Wink. https://github.com/kirbs-/sensi
It’s working on hassos now also. Thank you.
That library looks super old, but might work. I have thought about doing this work my self, my father has a Sensi thermostat and I am trying to move him off of Wink to HA. Is there a Sensi Android app?
I’ve got the sensi app on my android phone but it appears to not contact the thermostat but rather the sensi website that contacts the thermostat.
Yeah that makes sense. I am assuming there is no local API for the thermostat? Could probably proxy the Android app with Charles and collect the API calls.
I’ll try that now
There’s some more updated information here. Basically they have an API up, but it’s not really documented anywhere. They do have Android / IOS / and browser based control as well.
Okay, got another issue. Although I can now SEE the thermostat, I have lost control of it. This is all I get now:
This fixed my Sensi / HA integration, too. Thanks!
Ha! Okay, when I went to the States page and pulled up the climate.condo entity, I had full control. I had the above on my Lovelace interface page until I did a “refresh” on it. Go figure.
But all is well now.
Ah yes, the local browser cache can bite you after an update. I usually hold down Control and hit F5 in Chrome to force an “aggressive” refresh.
My sensors are all working BUT climate controls are not
Example:
Honeywell is no longer working
Did you install the custom component linked above? It won’t work without it on 0.96
ok I uploaded the zip again into the wink folder under custom and its still throwing specific error on the climate…
Blockquote
Jul 18 2019 20:54:15 GMT-0400 (Eastern Daylight Time)
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 365, in _async_add_entity
await entity.async_update_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 226, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 256, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 221, in state_attributes
data[ATTR_AUX_HEAT] = STATE_ON if self.is_aux_heat else STATE_OFF
File "/config/custom_components/wink/climate.py", line 195, in is_aux_heat
if self.wink.hvac_action_mode() == 'aux':
AttributeError: 'WinkThermostat' object has no attribute 'hvac_action_mode'
Yes I am using the zip from the above…
Oh good catch, that doesn’t look correct.
