This is honeywell thermistat
I’m getting this since updating to 96 and I don’t have my thermostat setup with the wink component.
What devices do you have in wink? Do you have a log file you can share?
Which log are you needing HA or WINK?
The HA logs. You should see something early on in the file showing a stack trace for that error.
@jlvandusen that log comment wasn’t for you sorry. that was for @Dayve67
I have my door lock, garage doors and a few lights and dimmers on the wink. Here is my log after a restart:
2019-07-18 20:38:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for wink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:38:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for breaking_changes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:38:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:38:19 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for authenticated which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:38:19 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for unifigateway which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:38:20 ERROR (MainThread) [homeassistant.components.sensor] netdata: Error on device update!
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 378, in async_device_update
await self.async_update()
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/netdata/sensor.py", line 131, in async_update
resource_data['dimensions'][self._element]['value'], 2) \
KeyError: 'received'
2019-07-18 20:38:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform wink.climate: Platform not found (cannot import name 'STATE_AUTO').
2019-07-18 20:59:53 WARNING (SyncWorker_0) [pyunifi.controller] Failed to perform <function Controller._read at 0x7f2745c33598> due to ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
There isn’t a wink error in that part of the log, are there any others errors?
2019-07-18 20:52:49 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:52:53 ERROR (SyncWorker_7) [homeassistant.components.octoprint] Endpoint: printer Failed to update OctoPrint status. Error: 409 Client Error: CONFLICT for url: http://192.168.1.20:80/api/printer
2019-07-18 20:54:09 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for wink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-18 20:54:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 365, in _async_add_entity
await entity.async_update_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 226, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 256, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 221, in state_attributes
data[ATTR_AUX_HEAT] = STATE_ON if self.is_aux_heat else STATE_OFF
File "/config/custom_components/wink/climate.py", line 195, in is_aux_heat
if self.wink.hvac_action_mode() == 'aux':
AttributeError: 'WinkThermostat' object has no attribute 'hvac_action_mode'
rebooting again - updated stand by caller
Are you sure you are running the correct zip? Try to delete the Wink folder entirely before putting the new one in place.
yes the second one you sent worked
That’s all I see. This one don’t mean anything?
Have you tried the new zip file? The error above shows you are already running a custom component for Wink. Did you have a custom component for Wink prior to having this issue?
I have not tried the new zip yet. Yes its the same custom component for before the update to 96.
Will try the new zip now.
OK it works but shows false readings now - shows Heat (its set for cool) and I have to keep refreshing the browser or click on another thermistat (ecobee) to get the correct controls - otherwise it shows the history only… very odd behavior.
Yeah, I think your old custom component is causing the problem for you. You should just be able to delete the custom component altogether and use the standard HA version.
Hmm that seems like some UI issues. Can you check the states page for the Wink climate device and see what it shows for the current state?
Error and Notification is now gone with the new custom component and even when I deleted it completely.
Thanks.
wink climate is not found… however I have the binary_sensor.wink_hub_2_0
manufacturer_device_model: wink_hub2
device_manufacturer: wink
model_name: Hub 2
update_needed: false
firmware_version: 4.3.60-0-g4d2358550e-hub2-app
pairing_mode: zigbee
kidde_radio_code: 10001111
friendly_name: Wink Hub 2.0
