Wink stopped logging temperature for climate component
Hi There ,
I wonder if somebody can help me out here because this has me completely puzzled.
Several days (weeks?) ago my history stopped showing the target as well as the current temperature in the history view.
It still shows both values in the status card:
And it also shows all expected values in the DevTools:
And here are the relevant entries from my configuration.yam - for testing I did not exclude or even include anything:
recorder:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Access to the Thermostat via Wink
wink:
  email: !secret wink_email
  password: !secret wink_pass
  client_id: !secret wink_client_id
  client_secret: !secret wink_secret
Anybody with the same issues or any idea?
Thanks!
So are you saying you don’t see this in the state card? Or are you not seeing it in the history side panel option? Or both? Are you seeing history for anything else?
I don’t see it in either place.
And everything else is showing fine in the history as far as I can tell.
This is what the stae card looks like:
hmmmm well that’s strange. I am not sure what would cause that. Like you said the data is there in the dev tools and there is nothing specific in any Wink code that controls history do you see any errors in your logs? Maybe try deleting your database?
I think I tried that before - and it helped for a little while (less than a day) and then the graph was missing again.
I’ll do it again just to make sure and keep you posted.
The only thing I can think of is that now and then - or maybe only once? - the data format of the temperature value changes from a number to something else (a string or Null value) which then results into the graph not being created. But I wouldn’t know how to check for that.
Deleted the database and saw it working for about 2h before it disappeared again from the state card and the history option from the side panel.
Set HASS up on a 2nd Pi3 with the thermostat through wink only - same result.
Interesting. What kind of thermostat do you have? Can you share the device with me via Wink? That would make it show up in my HA system so I can debug what’s going on.
Thanks @w1ll1am23 - I just shared the device. Highly appreciate the offer to help!
It’s actually an Emerson Sensi thermostat.
