[WIP] Smart dehumidifier
Because I never change the humidity setpoint, I stopped trying pretty quickly. I really just wanted to be able to turn it on/off and read current humidity and integration works fine for that.
Hi @v6ak ! thanks for your effort! I am struggling with the same thing as like @Astrofighter. Where should the 4 yaml.j2 files should be copy pasted? Thx
I’ve just come across this thread. I have a new Rohnson R-9920 dehumidifier and would like to integrate it with localtuya into Home Assistant. I’ve successfully paired it with the Rohnson app, and extracted the local key from the Tuya Developer account. The device can be controlled in the Rohnson app without issues. (I previously had it added to the Smart Life app, where it wasn’t working for some reason.)
I have localtuya installed. It lists the device by ID for “add a new device”. When I enter the local key and try to add it, it complains that it was able to connect to the device but didn’t find any data points. I assume that means that I need to add the values from the table upthread (e.g. “1 - switch”) manually via the “Manual DPS” field. Is that right?
I’ve tried adding a few fields like that (including 1, but also the sensors for temperature or humidity). Home Assistant adds and shows them correctly, but they are always “unavailable”. I’ve tried restarting the device and also Home Assistant a few times, but nothing changes.
Am I doing something wrong (this is the first time I’ve looked into localtuya)? Did something change e.g. with a new device firmware since 2022? What would be the best next steps for me to debug it?
Thanks a lot for any help!
I had same problem, but after some time sensors get back to online state
Thanks for info in this thread. Just wanna report I’ve got Ausclimate Desiccant 10L smart dehumidifier (sold in Australia) fully working through localtuya.
Just one thing unknown: DPS 19 is always 0. Assuming it should change to reflect tank full or something but I’ll wait and see since I just got the dehumifidier today.
I have just bought a Rohnson R-9530 dehumidifier and made it work (partly thanks to this thread too) with localtuya. However, the “mode” seems to be read-only. I have set it up like this:
          "friendly_name": "rh_mode",
          "select_options": "0;1;2",
          "select_options_friendly": "auto;sleep;clothes_dry",
          "restore_on_reconnect": false,
          "is_passive_entity": false,
          "id": 5,
          "platform": "select"
It displays the current mode instantly but when I try to switch it via HA, it has no effect. Is there some trick to it? The other controls work, like setting the target humidity level, switching the ionizer etc.
I have found out that my device actually needs the string, not a number. So I put “auto;sleep;clothes_dry” into select_options and now it works as intended.
Three years later - you are a life saver. I was just wondering what SMART dehumidifier to buy so I can hook it up with HA.
The reason behind is the current one is powered through a smart plug which I can confirm ruins the appliance as it cannot dry the condenser properly when turned off. A couple of months later there is mold on the condenser. This is the reason why brands warn to not use smart plugs. The dehumidifiers cannot finish their turning off cycle. Just is case someone was wondering - do not do this. Especially if the humidity levels in your home are very high.
I'm curious @starryalley which model Ausclimate did you get please - was it the ACD200 ?
