We definitely we don’t want to recommend people delete the storage files as it can impact other integrations!
As for your great suggestions:
Agreed, not working as intended, that should never happen. But I need more detail, Maybe having details from browser Developer console network tabs an help us figure out whats going? e.g. maybe an error payload in a browser response. on or turning up debug logging following the integration setup? Can we file a real github issue and fill out the template which asks for more details?
Thanks, TIL you can manage application credentials separately from integrations
No errors were returned in the developers console / network console, though I wish I add captured the actual request and response. I’m hesitant to risk breaking a working integration to capture debugging info, but I’ll consider it.
Yes, the app credentials are new in 2022.6 so expected that you haven’t heard about it yet.
I’m having a little trouble understanding your case compared to the previous report. In the previous case, they cleared out the credentials then saw the blank error message. In your case, i just see the can’t link error which is resolved by clearing credentials. Did you also see the blank error dialog? and when?
Yes I saw the blank dialog too. There’s a little more context in Nest integration presents blank dialog . Sorry, it was quite a long process of debugging and I encountered various errors.
As I recall, at some point I got the “can’t link” error. I discovered stored credentials in configuration.yaml and secrets.yaml and wiped those. Then I started getting the blank dialog box. Then trying again a day later (without changing anything on my end) it went back to the “can’t link” error. Finally clearing the stored application credentials fixed it.
Got it. Next person that hits this, file a github issue and we’ll talk there. It’s a bug, so it should be sent to developers so we can save the community from diagnosing.
I have looked for so long for this answer. I have had Nest Doorbel integration working, then Google changed their security I I kept messing around. Dozens of times redid all on Google Cloud. No sigar.
Till I found this post… so for those who had it working, but fail when reconfiguring:
!!! Remove the Application Credentials in the right top for Nest on the Integrations page !!!
Now Google can connect my account to HA and Nest is working. Finally. Thx!
