World Tide Info v2 API + graph
Hello
I’ve made some improvment in WordlTideInfo integration.
I take the API v2. I let the same current behaviour.
And I have the picture for the current tide !!
I will perform a pull request. Is there someone, that can tell me how to proceed ?
Thanks in advance
Philippe
Finally , I’ve found a way
Unfortunately, my pull request has been denied. (New rule request to have a PyPi library to access external ressource)
In order to share the work, I’ve put the custom component on github
https://github.com/jugla/worldtidesinfocustom
If you find mistake and you want to improve, thanks in advance fo comments/help
This looks great, but I’m not finding it in HACS.
EDIT: I see HACS inclusion status is “Pull request undergoing”, so I’ll wait :slight_smile:
I finally got around to migrating from the official component. This is great. Thanks. Example using and entities card and the “camera”:
Which card did you use for the following example from the your repository?
The last card is the history graph.
==> first is the sensor given by the declaration in configuration.yaml (in my example royan_tides).
==> the second is the current height, you create a sensor “template” that gives the value of an attribute of “royan_tides” (in my example tide_royan_current_height)
cf. https://github.com/jugla/worldtidesinfocustom
thnaks!
this is great.
here is my card using the image and some extra info.
elements:
  - entity: sensor.tide_worthing_station
    style:
      background-color: 'rgba(0, 0, 0, 0.3)'
      bottom: 0
      color: white
      font-size: 14px
      left: 0
      line-height: 34px
      padding: 0 15px
      pointer-events: none
      transform: initial
      font-weight: bold
      width: 100%
    type: state-label
  - entity: sensor.tide_worthing_current_height
    style:
      color: white
      font-size: 12px
      line-height: 32px
      margin: 150px 5px
      font-weight: bold
      right: 0
      top: 0
      transform: initial
    prefix: 'Current Tide Height : '
    type: state-label
  - entity: sensor.tide_worthing_next_high
    style:
      color: black
      font-size: 12px
      line-height: 32px
      margin: 1px 35px
      font-weight: bold
      right: 0
      top: 0
      transform: initial
    prefix: 'Next High Tide : '
    type: state-label
  - entity: sensor.tide_worthing_next_high_height
    style:
      color: black
      font-size: 12px
      line-height: 32px
      margin: 30px 35px
      font-weight: bold
      right: 0
      top: 0
      transform: initial
    prefix: 'High Tide Height: '
    type: state-label
  - icon: 'mdi:arrow-up-bold'
    style:
      color: black
      line-height: 32px
      margin: 39px 20px
      right: 0
      top: 0
      transform: scale(0.8)
    type: icon
  - entity: sensor.tide_worthing_next_low
    style:
      color: black
      font-weight: bold
      font-size: 12px
      line-height: 32px
      margin: 59px 35px
      right: 0
      top: 0
      transform: initial
    prefix: 'Next Low Tide : '
    type: state-label
  - entity: sensor.tide_worthing_next_low_height
    style:
      color: black
      font-weight: bold
      font-size: 12px
      line-height: 32px
      margin: 84px 35px
      right: 0
      top: 0
      transform: initial
    type: state-label
    prefix: 'Low Tide Height : '
  - icon: 'mdi:arrow-down-bold'
    style:
      color: black
      line-height: 40px
      margin: 88px 20px
      right: 0
      top: 0
    type: icon
image: local/worthing_tides.png
type: picture-elements
Whaow !! Thanks a lot !
In the card picture-elements , are the pictures reload automatically if there is a change ?
Your code works well !
glad it worked! you might want to change “Royan” to be whatever your local area would be - i think royan is where the code creator is from maybe?
Royan is the town where I wanted to see the tides !! :wink:
I thouht , it was easier to give example rather than rules in https://github.com/jugla/worldtidesinfocustom
To display “Royan” hereabove , I’ve taken (I think like you) the attribute that gives the reference tide station :wink:
awesome :slight_smile:
Thanks for creating this - really helpful
Hello
In order to picture element to refresh picture you have to replace
by the camera
camera_image: camera.royan_tides_curve
(the solution has been given https://community.home-assistant.io/t/refresh-cached-images-in-lovelace-picture-elements-maybe-other-places-too/98351 )
Is anyone able to help please.
Relatively new to HA.
Have been going round and round but entities not working or being generated, im sure it is a syntax issue somewhere as I have other custom sensors which load fine. In the entities it only finds the camera??
# WorldTides
  - platform: worldtidesinfocustom
    api_key: ..........
    latitude: 50.917
    longitude: 0.967
    #    station_distance: 10
    #    vertical_ref : LAT
    #    scan_interval: 900
    #    worldtides_request_interval: 90000
    sensors:
      tide_dungeness_next_high:
        value_template: '{{ as_timestamp(states.sensor.dungeness_tides.attributes.high_tide_time_utc) | timestamp_custom("%a %d/%m/%Y %H:%M") }}'
        friendly_name: "Dungeness Next High Tide"
      tide_dungeness_next_low:
        value_template: >
          {{ as_timestamp(states.sensor.dungeness_tides.attributes.low_tide_time_utc) | timestamp_custom("%a %d/%m/%Y %H:%M") }}
        friendly_name: 'Dungeness Next Low Tide'
      tide_dungeness_next_high_height:
        value_template: "{{ state_attr('sensor.dungeness_tides','high_tide_height')  }}"
        friendly_name: 'Dungeness Next High Tide Height'
        unit_of_measurement: m
      tide_dungeness_next_low_height:
        value_template: "{{ state_attr('sensor.dungeness_tides','low_tide_height')  }}"
        friendly_name: 'Dungeness Next Low Tide Height'
      tide_dungeness_credit:
        value_template: "{{ state_attr('sensor.dungeness_tides','CreditCallUsed')  }}"
        friendly_name: 'Dungeness Tide Credit'
        unit_of_measurement: credit
      tide_dungeness_current_height:
        value_template: "{{ state_attr('sensor.dungeness_tides','current_height')  }}"
        friendly_name: 'Dungeness Tide Current Height'
      tide_dungeness_station:
        value_template: "{{ state_attr('sensor.dungeness_tides','tidal_station_used')  }}"
        friendly_name: 'Dungeness Tide Station used'
camera:
  - platform: generic
    still_image_url: https://127.0.0.1:8123/local/dungeness_tides.png
    verify_ssl: false
Please have you install the worldtidesinfocustom “custom component”?
It is not by default in HomeAssistant (HA).
Please first install hacs, https://hacs.xyz/
then worldtidesinfocustom https://github.com/jugla/worldtidesinfocustom
Yes it is installed, i have also removed and re-installed to try and fix
Just with the first declaration ,
# WorldTides
    api_key: ..........
    latitude: 50.917
    longitude: 0.967
it works
Do you have anything in logs related to tides ? (Look in your configuration directory inside home-assistant.log)
Please can you see in your configuration directory/custom_components the worldtidesinfocustom directory ?
So I just deleted everything in yaml and integration from hacs. I then when through adding everything again and now working.
Not sure how/why as all code was copied both times from instructions.
Many thanks for the support and work on this
your welcome !
and thanks for your comments :slight_smile:
