I have over 6000 entities in my Home-Assistant installation, each time I add a new device or re-pair one, all entities are exposed to Assist automatically. Also meaning a lot of information gets sent to assist when I use it.
I would like to have an easy configuration switch that disables automatically exposing entities to Assist so that I can manually expose only the ones pertinent to have in the voice assistant.
I know I can disable them in the configuration, but I shouldn’t need to revisit this on a monthly basis to keep the Assist entities reasonably sized.
This is something that was also requested in the past:
While I love having those in a “Network” dashboard and have the possibility to enable/disable switch ports in the interface, it is definitely not something I will interact with by voice command and would hate for a misinterpreted command to turn off an important switch port.
Same, it’s especially annoying when you add a new integration and don’t check the exposed entities in Assist afterwards, sometimes it can mess up even standard speech processing engine when there are duplicate names (Google Cast integration did this with my TV recently).
Not to mention this messes up LLM pipelines, maybe even costing people more due to HA using more tokens.
I also voted for this ! I find it important because I will use ChatGPT and I hope I will be able to let my kids interact with the HA Assist. Because of this this I want to leave a limited set of entities.
BTW.: How can I mass-UNexpose entities from Assist ? If I select multiple entities and click “unexpose” it affects only google assistant. The only solution I see is to remove by clickling the “X” in the right side for each entity I want to remove …
