Basically, I would like to be able to check if my door has been open any time in the last ‘x’ minutes/hours despite if it is now closed via the UI.
What? Do you mean “Was my door open at any time during the last hour”?
You can check that with the states.my.entity.last_changed attribute, although a little cumbersome I admit.
The answer to that will always be false
Did you perhaps mean this?
Check if my door has been open any time in the last hour despite if it is now closed.
If so:
condition:
condition: or
conditions:
- condition: state
entity_id: binary_sensor.door
state: 'on'
- condition: template
value_template: "{{ states.binary_sensor.door.last_changed > now() - timedelta(minutes=60) }}"
Or in shorthand notation:
condition:
or:
- condition: state
state: 'on'
- "{{ states.binary_sensor.door.last_changed > now() - timedelta(minutes=60) }}"
but this will tell me if the door sensor changed in the past hour… It can go into several states… “unavailable” for example…
I gave the door as an example… but I would use it in other circumstances as well… for example. to check if a person was at work (zone) this morning etc…
Probably it can be achieved via templating… but I guess the goal of the WTH is to make it more user friendly…
This is example of something you could use History Stats sensors for…
- platform: history_stats
name: Door open last hour
entity_id: binary_sensor.my_door
state: "on"
type: count
duration: "01:00:00"
end: "{{ now() }}"
This would give you a sensor with a value of 0 if the door had not been open in the last hour.
Consider voting for History stats in the UI
Is there a smarter solution than this one meanwhile?
If history_stats would be configurable from the UI this would maybe be a more attractive approach.
