WTH can't I press a physical button when creating an automation to use it as a trigger?
I have a zigbee button that shows log info that it’s being pressed, but when I go to make an automation, the entities aren’t there. Why can’t I select “Trigger” > then be able to choose from a list of recently pressed buttons and switches? It would make the process of adding automations so much easier.
Thanks, that fixed my immediate issue. I think my WTH still stands, as it should be way easier to link automations to buttons, especially since the triggers aren’t listed on the main device/entities page
Yes, I agree. I know there is an ongoing effort to change the way ZHA handles button press events. That effort has been around for a while, but it seems to be close now. see Standardized button event entities for ZHA remotes · Issue #961 · zigpy/zha · GitHub
If you put the automation entity on dashboard , you can execute by pressing on it.
Thanks, that’s what I ended up with. I was referring to the process of setting up the button. I have a few zigbee remotes with 4 buttons, each with three actions, and it takes a ton of clicking through menus to find all the triggers
