WTH can't we snooze automations
It’s possible to disable an automation, but it would be really great if we could disable them only for a specified time period – ie, snooze them.
My shades are set to go up at 6am on weekdays. Sometimes I’d like to turn it off for a day, but I I need to disable it then remember to re-enable it. Would be really nice if there were just a snooze option…
Don’t forget to vote for your own WTH
Hey Ben, I’m fairly new to HA, but why don’t you just create a helper called “MyShades” as an on or off. Add that as a condition to your automation and if you turn off the helper, your shades don’t work, turn it on they do. I did this with my garage door opener… I created a helper for myself and my wife for Automatic Garage Door opening. If we turn it on, when we arrive in the Home Zone, the garage will open, but it is specific to the individual. It allows us to turn them both off when we don’t want it to happen automatically.
Functionally, this probably would work well alongside temporary automations with timers, HA could create an automation that disabled the automation until a time specified then removes itself (or moves to a recycle bin)
There are many ways to do this yourself using automations. A simple way is to create a timer helper and add a condition to your automation that the timer must not be running. Then you can start the timer for the tome you want to snooze. And you can still use the automation disable for normal disabling.
I do actually have that built for a few automations. But it is manual and requires front end work for each automation. I have 58 automations. I, for one, would vastly prefer if it were just part of the main system.
Wouldn’t that amount to just a single Input Boolean per automation?
The automation triggers at 06:00, confirms its associated Input Boolean is on then proceeds to execute its actions. If it’s off, it simply ends without executing actions.
A separate automation manages the Input Boolean(s), turning it/them back off after a predetermined period of time.
It’s so trivial to implement (and customize) that it makes it unlikely be created as a dedicated feature.
Well, mine require more than a single input boolean. You at least need another input for the time to snooze, unless you want them all to snooze for the same period, which seems suboptimal. Yes, it is simple, but but having to do it for 57 separate automations just seems unnecessarily repetitive Would be better for me if this were just a part of the UI. And seems like a really simple thing to add.
In over six years of participating in this forum, this is the first time I ever heard anyone need to snooze dozens of automations. It’s such an “outlier” requirement that the odds are low for implementation.
Are you familiar with software development for Home Assistant?
  • If yes, you can submit a PR to the Core repo. You may first need to submit the idea in the Architecture repo because it alters the way automations currently work.
  • If no, then what metric was used to judge the relative ease of implementation?
I think you should be able to achieve this with a single script with two fields, one for selecting the automation, one for time (assuming you even want the time to be customizable). Though maybe in practice it would be better to have one script per automation, easier to use them.
I haven’t tried doing this exactly, but I’m using it for turning a device on and then off after a customizable delay. No need to create helpers.
This could probably be made to incorporate the use of the local calendar making it possible to easily get an overview of snoozed automations.
Using the Calendar triggers Automation Trigger - Home Assistant it should then be fairly easy to disable/enable the automation again.
I fully respect your view that it would be easy to work around. All I can say as that an end user, I would really appreciate the ability to snooze automations directly from the UI.
I think it’s still somewhat of a niche thing to interact with the an automation in this way, but if you just want to toggle it on and off you can simple do this.
I do wish some more high quality blueprints where included with home assistant from start where they would be easily searchable. Then things like this could be more easily be supported.
You can also use entities card for multiple automations. I do that for some and it works nicely.
But yeah, even though there are some workarounds, I agree it would be nice to have such option built in, so I added my vote.
What???
You have 57 automation just for your shades?
Well… there’s your problem!
You could probably do that in just a few.
That would be quite a few shades. No, I have 57 different automations, some part I’ve wanted to snooze for various reasons. But shades in multiple rooms is one set (ie, want to snooze the guest room but not the kids rooms or vice versa). I have a motion sensor in the back yard which turns on the lights but want to snooze when my son is using his telescope. Or alert automations when something goes offline but I want to snooze while the electrician is working. Etc, etc. There have been many many times when I have asked WTH there isn’t a snooze function….
I understand it’s not a problem for everyone. That’s ok. It’s a problem for me. There seem to be more than my upvote here. It’s not an unsolvable problem, but it’s an annoyance for me and seems at least a few others.
I think the easiest way would be to disable the automation.
Then set up an automation that triggers on any automation being disabled for 1 hour and enables it again.
I would probably add that if the name of the automation starts with “Disabled” then it should not enable the automation.
This means you need to rename the automation if you want it permanently off.
I have this script to turn on whatever entity in a specified time:
alias: Turn on within
icon: mdi:location-enter
mode: parallel
sequence:
  - delay: "{{timeField}}"
  - target:
      entity_id: "{{entityField}}"
    data: {}
    action: homeassistant.turn_on
  - target:
    data: {}
    action: switch.turn_on
  - target:
    data: {}
    action: light.turn_on
  - target:
    data: {}
    action: script.turn_on
  - target:
    data: {}
    action: scene.turn_on
  - target:
    data: {}
    action: input_boolean.turn_on
  - metadata: {}
    data: {}
    action: cover.open_cover
  - metadata: {}
    data: {}
    action: timer.start
fields:
  entityField:
    selector:
      entity:
        multiple: true
    required: true
  timeField:
    selector:
      time: {}
    name: Turn on in
    required: true
    description: Set time to wait before turn on entities.
It looks like this in UI, you can select as many entities as you want:
I have a similar one to turn off entities.
You can build this your own. Have an automation triggered on the automation state off for a certain amount of time and have it toggled.
Here’s what I use:
alias: Time based state restore
description: …
mode: queued
triggers:
  - entity_id:
      - automation.example01
      - automation.example02
    to: "off"
    for:
      hours: 0
      minutes: 30
      seconds: 0
    variables:
      trigger_service_call: automation.toggle
    trigger: state
  - entity_id:
      - automation.example03
      - automation.example04
    to: "off"
    for:
      hours: 1
      minutes: 0
      seconds: 0
    variables:
    trigger: state
  - entity_id:
      - input_boolean.motion_detect
    to: "off"
    for:
      hours: 1
      minutes: 0
      seconds: 0
    variables:
      trigger_service_call: input_boolean.turn_on
    trigger: state
conditions: []
actions:
  - data: {}
      entity_id: "{{ trigger.entity_id }}"
    action: "{{ trigger_service_call }}"
Having that said, another solution is to use a helper that toggles at a certain moment and have that helper in the conditions of your shade automations.
Thanks! I see lots of ways to program this, all of which require upkeep, maintenance and programming.
I also had my pages arranged in sections before the section view was available. The section view just makes it so so much easier to maintain and change.
It’s the same for snoozing. Just because you can find work arounds doesn’t mean that adding it to the core isn’t a good thing. If it isn’t for you, I understand and salute you. It would be great for me, and seemingly a few others here.
