WTH is there no way to insert common templates into template fields?
f.e. a button with dropdown list to insert things like get entity state ( or attribute) .
I imagine this similar as f.e. in some text editors i can insert some regular expressions for searching.
Or at least a help popup i can copy the yaml from.
Every time i need this i have to look up the syntax i dont remember correctly.
I think this would be of much help for new users.
This may only work for simple templates like
{{ states('sensor.xxx') }}
or
{{ state_attr('sensor.xxx','some_attr') }}
But templates may be very complex. So what is the point to add a functionality which covers 1% of possible variants?
you can insert the basics on cursor position and extend it as you need.
But what “basics” are?
like your examples + some common used filters, is_state(), such things.
To be discussed or to get from any statistic :slight_smile:
Things a new user or one not writing templates every day could need.
I am unsure everytime if its state or states, hw to get attributes, i forgot the ’ ’ and so on.
In forum questions i often see missing float(0) on number entities
