Why the heck is Py-Spy not integrated in Home-Assistant?
With CPU or memory problems, Py-Spy is frequently referred to, but anyone using Home Assistant Operating System doesn’t even have the option to install it. Py-spy in Home Assistant running on RPi 3 with HassOS-based image
Isn’t it possible to turn this into a service, so that if your CPU peaks you can create an automation to start a Py-Spy session?
This makes it easier for everyone to pass debug info to the developers.
