One frustration is when editing and change from Visual to Code Editor, the screen size is set and can’t be resized.
Suggestions:
I did while writing this discover that indeed one can Double Click Header to resize.
A Maximise button somewhere on the screen would help as it is certainly not obvious.
Option to resize the “Split Screen” rather than it being 50/50 which leaves a lot of wasted space which would be served better on the editing screen if one could resize the split.
HI Tom,
I can try and hope it makes sense.
In short: More resize options within the Editing Window as currently one can only maximise by double clicking the header (assuming one knows that trick).
