WTH - Reorder Items in an Automation/Script
It would be great if we could drag and drop Triggers/Conditions/Actions in automation/script or be able to easily move items up and down within the automation/script.
This is a good one, I had to delete items as I couldn’t move them when a move would seem like a logical feature
Yes… Second this.
Automations (and scripts) match from the top down so this would make it easier than copy/pasting in the raw YAML in order to re-order action lists
You can already do this. In the automation, click the menu icon in the top right corner and select “reorder”
To be specific, click the kabob in the upper right of the automation/script and select Re-order:
Then, use the arrows next to each action:
CleanShot 2022-10-05 at 14.28.10
I had that issue too. They really hid that option two updates ago! It took a minute to find.
If you go to your profile and click EDIT on “Change the order and hide items from the sidebar” it detaches the sidebar items allowing you to move them around very quickly or remove (unpin) them altogether.
This would be ideal for automations as you can only hop 1 step at a time the current way
You can literally drag items, anywhere. You’re making assumptions about the screenshots without trying it. But next to the arrows is grab handles that do exactly what you want.
Oh wow … yes.
That’s new :smiley:
